- Thank you received: 109
Heads
- mark1122
- Keep twisting it
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Duck
- e vica na i sau na ga
82 same as J except for tapped hole for CHT sensor. This I do know, having both.
83/84, I have read, has a different combustion chamber, bathtub instead of hemi, shape but I have not seen one.
Still have not had a chance to get to the workshop since returning from HI 2.5 weeks ago. Linda gave me an arm long list of chores to have done before she arrives in Dec. Mostly plastering as the fist thing on the list and need about 10 min every hour to give arms a rest. By the time I get fast at it, I'll be done
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- Duck
You can plumb nitros into the gpz head through the F/I ports! :ohmy:
Only 81 has ports in head.
- Duck
did you say you have to give your arms a rest so you can get plasterd?that must be one heavy bottle.:blink: :silly:
32oz Modelos in those 5lb Mexican Restaurant mugs
Seriously, I'm replacing the rotten skim coat on 80 year old plaster walls. Take it off with a plane. Put it on with a trowel. Sand out trowel marks. The more plastering I do, the better I get. Result is less sanding as the project progresses. Arms will be in good shape for painting
- APE Jay
- Banned
- Thank you received: 58
The '83-84 heads are the bathtub chamber and slightly larger valves.
As for which one to put on a KZ lower end?, Use the early hemi style. The reason is that you can use J/GPZ pistons and a .040" spacer plate and have the correct piston dome to match the head. If you use the 83-84 head you can't do that as the 83-84 pistons have 18mm pins.
Jay
- kano
- Not Another Bloody Limey!
i would prob do it just for looks as i doubt i can get over 120 here anyway.
as i have the head in question on my elr.
- larrycavan
- Visitor
83-85 GPz / 84-85 LTD - Intake runners are considerablly larger with the largest intakes and exhaust valves Kaw used on any of their KZ or J motors. Outflows on avg 10cfm @.400" lift /10"Pressure] more than KZ or J. 82 vs 72
Standard J head from any model exclusing above, 1mm over valves, runners are larger than KZ but on average doesn't flow anything to write home about..Low 70s at above test pressure and lift.
J series heads require less work when 33mm or larger carbs are your target size.
Post edited by: larrycavan, at: 2006/11/15 16:59
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- racer54
- Thank you received: 114
