- Thank you received: 512
Metal in oil
- baldy110
Anyone have any ideas.
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Pterosaur
- Visitor
Might be worth getting a couple of filters and a couple change's worth of cheep-o oil, do a change, run it awhile, do another change and see if the quantity of metal in the oil tails off...
- kzwolfsr
- Thank you received: 16
Original man of the Caribbean
- baldy110
I also thought it might be the clutch plates but I have seen a lot of oil contaminated by clutch plate residue and this aint it. I am getting very small slivers of aluminum. You can see it floating around in the oil and it settles on the bottom of the container. This bike does not have an oil filter, I wish it did it would make finding the source easier. Honda simply put in a small screen right before the oil pump pickup
Now what has me really confused is the amount of metal. After the first rebuild, yes I have taken this thing apart four times in the last month I fired up the engine and ran it for about 30 seconds. I drained the oild and there was a laot of metal in just 30 seconds of running. You would think that the source would be pretty easy to spot with the amount of metal it was making but so far I can't find it. I have been rebuilding all types of motorcycle engines for a long time and this one has me stumped.
Post edited by: baldy110, at: 2006/11/10 20:58
Post edited by: baldy110, at: 2006/11/10 20:59
- steell
- kano
- Not Another Bloody Limey!
just slowly working its way out.
- baldy110
- Pterosaur
- Visitor
...Now what has me really confused is the amount of metal. After the first rebuild, yes I have taken this thing apart four times in the last month I fired up the engine and ran it for about 30 seconds. I drained the oild and there was a laot of metal in just 30 seconds of running. You would think that the source would be pretty easy to spot with the amount of metal it was making but so far I can't find it. I have been rebuilding all types of motorcycle engines for a long time and this one has me stumped.
Yowza.
(Noted the lack of oil filter and clutch residue...)
You'd think that amount of metal - and the type - shavings and such - *especially* in a 30 second-run time frame - that the motor would have sounded like a coffee grinder chewing on a coconut.
Gotta go with Steell - *something* ain't right in there.
Even the most experienced screw up from time to time - saw a wrench left in an oil pan one time by a guy I'da swore would never have done it.
Best advice I can come up with at this stage is to tear her down again and look for fresh marks in the innards - if it's eating itself from the inside out like that, there's gonna be clues somewhere...
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Duck
- e vica na i sau na ga
BTW, I need a good cylinder head but only have $100 for it
- baldy110
