KZ900 Bore Question
- bkitchen
09 Nov 2006 19:04 #90895
by bkitchen
KZ900 Bore Question was created by bkitchen
- bkitchen
09 Nov 2006 19:05 #90896
by bkitchen
Replied by bkitchen on topic KZ900 Bore Question
- mark1122
- Keep twisting it
- Thank you received: 109
09 Nov 2006 22:09 #90938
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic KZ900 Bore Question
APE. means American performance engineering.They are a very big parts comp. They sell those half moon cam plugs.The only way to know the piston size is to measure the bore diameter.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
- Visitor
10 Nov 2006 08:40 #91008
by wireman
Replied by wireman on topic KZ900 Bore Question
could be anywhere from 903 to 1197;)
- KZ_Rage
- Kentucky Bourbon Barrel Ale
- Thank you received: 19
10 Nov 2006 10:37 #91045
by KZ_Rage
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Replied by KZ_Rage on topic KZ900 Bore Question
Could be bored or just honed as some folks call a honed engine "bored"! :blink:
Unless you're going to open it up I wouldn't worry about it. If there is plenty of compression and you get a good result from a leak down test, I'd leave it alone. You can check for proper carb setup on the "bored out" job by doing a colortune. From the looks of the outside of the carbs I'd say that is where you need to spend some time for sure. Clean them, re-balance and see what it does. If it bogs or pops then address the carbs jets/needles.
The bike is a find at 4 times that price, good fortune has smiled upon you!
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
