Valve Adjustment and Synthetic Oil
- dbroten
19 Nov 2005 19:19
Got a '79KZ650SR last year (20,000 miles) and have decided to complete a valve adjustment to get it running just as smoothly as I can. Have already had the cam chain adjusted. Any suggestions for what to watch out for? Also using synthetic Amsoil in the engine. Any comments on that.
- Fossil
Re: Valve Adjustment and Synthetic Oil
19 Nov 2005 21:37
The synthetic issue has come up here before, do a search to see what was discussed. I'm using Castrol Syntec Synthetic, no problems, but I did notice smoother shifting.
- Cactus
20 Nov 2005 12:01
Shim check and valve chain slack are standard 5000kms maintainance on the zeds. Semi synth and fully synth work fine on mine, so I've been on fully synth for a few months now, I always buy oil up to the G or L standard, check out the back of the can.
- dbroten
22 Nov 2005 17:53
Fossil and Cactus:
Thanks for the comments. I'll see how things go. Can't wait for spring!
- Warthog
22 Nov 2005 18:06
Here is a stupid question.
Isn't the cam chain adjustment on the 79 automatic. If so how do you adjust it? I have a 79 KZ650 and I would like to know if I need to adjust my cam chain.
This message brought to you by Hotdog
- dbroten
23 Nov 2005 19:05
Warthog: My understanding is that the cam chain is not automatically adjustable. I remember reading about it in the manual I obtained and I had my mechanic do some adjusting on it so I think it is non-automatic. I am always ready to be corrected, however. Good question, though.
- RonKZ650
23 Nov 2005 19:22
The 1979 models are automatic. This is assuming the original tensioner is still on the engine. You can tell by looking at your tensioner. If the 10mm head bolt on the side of it is tightened up flush with the body it is a 1979 or newer auto type. If it has a 10mm head bolt that shows several threads and has a 10mm jamnut securing it to the tensioner its a 1978 or older manual type. The manual is the better tensioner, has more adjustment range for worn out camchains. The automatic is fine for a good camchain which should be at least 80,000 miles.
dbroten wrote:
- dbroten
25 Nov 2005 11:23
Ron: Thanks for the input. I will look at the tensioner and see what it is like. This is why I always say: "...it is my understanding that..." Thanks again!
