Heavy duty studs
- tullymars
Heavy duty studs
08 Nov 2006 12:30
Installing heavy duty studs,do I locktite all of them or is there something different with the four outside studs?Seems like I use to put silicone on them,been a long time
- The Milkman
Re: Heavy duty studs
08 Nov 2006 15:33
Ooops!!! I read your subject wrong... I thought you were looking for guys like PT, Scrapper and me. :laugh: :laugh: :woohoo: :woohoo: :lol: :lol: :evil:
- wireman
08 Nov 2006 16:29
ive got one of those stupid questions,why are you using the heavy duty studs?if you decide to use them id reccomend using the stock studs on outside holes since tey are necked down to aid oil flow through oil gallerys of head.id say put some anti seize on them and torque to whatever the manufacturers instructions say.
- APE Jay
08 Nov 2006 19:50
We do not recommend Loctiting the studs in the case. Just torque then to 8 lbs.
A very serious problem on some KZs that people Loctited the studs is some of the stud holes in certain models have an opening to the main bearing area.
People have over done the Locktite and had it run into the main bearings.
Jay
Jay
- APE Jay
08 Nov 2006 19:52
wireman wrote:
There has never been an issue with oil getting up past the big studs.
Jay
Jay
