Kerker
- mark1122
- Keep twisting it
Kerker
07 Nov 2006 22:14
Anyone have a problem with a flat spot at mid rpm wot after installing a header?Could it be the baffle size or lack of? I heard some old pipes did this.So Im wondering if my flat spot may be my Kerker.I had it with my vm29's,and still with my 33's.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- scumbag
- Lewd, Screwed, and Tattooed
Re: Kerker
07 Nov 2006 22:29
except for in two strokes I have never had a header induced flatspot...it has aways been carbs...are your carbs set to spec?
someone else chime in but thats just my experience
sept.1976 kz650
1980 kz650
1980 kz650
- letthegoodtimesroll
Re: Kerker
08 Nov 2006 05:14
I have had Kerkers on 2 different KZ650s and never had any trouble. One had pods and the other didn't.
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
- pyxen
Re: Kerker
08 Nov 2006 06:49
I had a flat spot around 5grand with my Supertrapp exhaust - when its dialed in for HP, and lower backpressure that is.
Once I tuned it down to increase low-end torque, it went away.
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- CoreyClough
- GPz550 Addiction
Re: Kerker
08 Nov 2006 06:54
I thought the smooth bore carbs work more like an on/off switch(well maybe not that extreme).
'85 GPz550(ZX550-A2)
- mark1122
- Keep twisting it
Re: Kerker
08 Nov 2006 09:08
When I got the bike(25years ago)it had no baffle and vm29's.Then I put in bigger intakes,and vm33's.same flat spot.I just fabbed up a baffle and the flat spot is still there but it moved down in rpm.I'm just not sure if it move down due to the baffle or carb jetting changes ? I'll have to try pulling the baffle again next spring and see what happens.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
Re: Kerker
08 Nov 2006 09:11
pyxen wrote:
Corey,what do you mean by "I thought the smooth bore carbs work more like an on/off switch(well maybe not that extreme)."
can you explain how you dialed it in.Im not formilar with supertraps.I had a flat spot around 5grand with my Supertrapp exhaust - when its dialed in for HP, and lower backpressure that is.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- CoreyClough
- GPz550 Addiction
Re: Kerker
08 Nov 2006 13:12
Not just "up-ing my post count, but there was something a little bit back where someone had added those to their bike, and had the on/off switch ridability. I might be wrong, and someone please correct me if I am. Ask Wiredgeorge, as he seems to be the Carb King.
tinyurl.com/ea6n
tinyurl.com/ea6n
- mark1122
- Keep twisting it
Re: Kerker
08 Nov 2006 16:16
I havent heard that one before.It does make sence that they may move the power band up a little.But you also get a lot more power.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
