best results
- Brown
best results
07 Nov 2006 09:50
I've wiseco 1385/82mm piston kit,and needing some help with the cams I do not want to go with a cam too large because I would need under the bucket shims and to me that is a nightmare headache what would be the best lift and still use top of the bucket shims and make good HP all suggestion welcome:whistle:
- cary
Re: best results
07 Nov 2006 10:14
APE says that their 410's will work with over bucket shims. and uh, by the way.... I don't think power will be a problem with that kit. maybe putting it to the ground though, good luck!
- RomSpaceKnight
Re: best results
07 Nov 2006 17:43
I would say under .400 lift with shim overs. I went through hassle to go to shim under with .380 lift. Your call. What is risk scenario and consequences for not going to shim under?
- wireman
Re: best results
07 Nov 2006 17:52
whats the rest of your setup motor and chassis,whats it gonna be used for?its best to have a mtched setup so everything works together in my experiance of parts torturing!:evil:
- Ron G
Re: best results
07 Nov 2006 19:35Please Log in or Create an account to join the conversation.
