  • JMKZHI
  • JMKZHI's Avatar Topic Author
07 Nov 2006 09:25 - 22 Feb 2013 11:38
#90246
Last edit: 22 Feb 2013 11:38 by JMKZHI.
  • cary
  • cary's Avatar
Re: Exhaust pipe internal coatings?
07 Nov 2006 10:18
#90257
maybe you could spray a can of VHT exhaust paint into the header and let it run down and coat the insides?
  • JMKZHI
Re: .
07 Nov 2006 11:17 - 22 Feb 2013 11:38
#90263
07 Nov 2006 11:46
#90265
Some of the OEM exhaust header pipes were double walled with a smaller internal pipe protecting the outside pipe from excessive heat. Am wondering if the rusty flaking inside you see is actually on the inside of the internal pipe which might be of lesser concern to you. Just a thought. Am unfamilar with Evapo-Rust, but would agree as to spraying with VHT as Cary suggested.
Post edited by: Patton, at: 2006/11/07 14:50
  • flht1997
  • flht1997's Avatar
07 Nov 2006 11:47
#90266
i had the Thunderheader on my older HD internally powdercoated to try to reduce the "bluing" well it still got blue, but i had it pretty advanced and lean, but the inside of the header looked like greased snot. it does reduce the temp a little bit. and i would bet it would do a good number on stopping rust.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • steell
  • steell's Avatar
07 Nov 2006 14:32
#90292
Way back when dinosaurs roamed the Earth, the hot trick with the Brit 650 twins exhaust was to pack the pipe full of grease (at the engine side) when installing new pipes. It created an awful lot of smoke when first started, but the pipes never blued after that :)
Post edited by: steell, at: 2006/11/07 17:33
  • JMKZHI
Re: .
08 Nov 2006 05:27 - 22 Feb 2013 11:38
#90439
  • JMKZHI
Re: .
08 Nov 2006 07:45 - 22 Feb 2013 11:38
#90459
