Problems Splitting My Case
  • Kellen79_650
  • Kellen79_650's Avatar Topic Author
05 Nov 2006 20:59
#89906
I am rebuilding a kz650 and I have the engine stripped down and by all accounts am ready to split the case. Only problem is, it won't budge. I followed the steps in the strip down tutorial, all bolts holding it together are out. I don't know if I am just missing something obvious or there is a trick to it. Any ideas? Here are two pictures if they help.
"In the beginning of a change, the Patriot is a scarce man, Brave, Hated and Scorned. When his cause succeeds however, the timid join him, for then it costs NOTHING to be a Patriot."
~Mark Twain
  • Kellen79_650
Re: Problems Splitting My Case
05 Nov 2006 21:00
#89907
#2
~Mark Twain
  • nads.com
  • nads.com's Avatar
05 Nov 2006 22:00
#89920
I may be mistaken but I believe there are more bolts underneath the oil pan. Crankshaft bolts.
  • Kellen79_650
05 Nov 2006 22:01
#89921
Did a little more searching in the forum and I found out 2 more bolts were trying to hide from me under the oil pan. Sneaky little buggers aren't they? Problem solved!
~Mark Twain
  • kzwolfsr
  • kzwolfsr's Avatar
02 Dec 2006 14:05
#96829
Reminds me of the old days, well when I rebuilt my engine. There was a long screw in the back of the tranny and then I took a screw driver and wedged it in the back of the tranny where ther is this little slot and then there is another 2 slots, one on the left side in your pic right behind theoutput shaft where the front sprocket goes on and the next on the right in the clutch area above thatshaft thing that sticks out.
Original man of the Caribbean
  • larrycavan
  • larrycavan's Avatar
02 Dec 2006 18:09
#96904
Kellen79_650 wrote:
#2
Glad you solved the bolt issue....wanted to give you a huge thumbs up on the tag lines....Good to read them....Great to see more people coming out of the sleep this country has been in....Hope 07 is a great year for you and yours!
JMO
Larry C
