will a 900 engine fit into a 750 frame?
  • sapper7
  • sapper7's Avatar Topic Author
05 Nov 2006 09:43
#89809
Curious if a KZ900 engine will fit into a 1981 KZ750E frame. Concerned about the sprocket and mounting bolt alignment. Any advice? Not worried about carbs and electrical issues:evil:
  • 77KZ650
  • 77KZ650's Avatar
Re: will a 900 engine fit into a 750 frame?
05 Nov 2006 13:54
#89833
thats a 750/4 not a 750 twin right?
Scott
07 MDP Rookie of the Year
  • wireman
  • wireman's Avatar
05 Nov 2006 14:16
#89835
sapper;) in the wire are ya?:S
  • sapper7
05 Nov 2006 15:24
#89853
Yes, I have a 4 cylinder 750 in the bike at the moment. The engine runs great but having problem with the starter gears in the gearbox. Replaced the starter and still having problems grinding gears. If I have to pull the engine and look for parts I was thinking of replacing the entire engine with something larger.
Post edited by: sapper7, at: 2006/11/05 18:27
  • sapper7
05 Nov 2006 15:37
#89857
6 years Combat Engineer, 3 Duty Stations and 3 Deployments. Got out on 2000.
  • steell
  • steell's Avatar
05 Nov 2006 15:43
#89858
There has been more than one person put a 1000 in a 650 frame, so I'd say a 900 in a 750 frame is do-able :)
I can say with certainty, that a 1000 J "IS" going to fit in a GPz750 frame :D
  • wireman
  • wireman's Avatar
05 Nov 2006 19:35
#89887
i saw a guy put a hotrodded 327 chevy with a tunnel ram and dual 4s with a powerglide behind it in the front of a fiat one time,it was was crude as hell but it was freaking fast as hell!:evil: you can make anything fit with a torch and a big hammer!:P
  • 77KZ650
  • 77KZ650's Avatar
05 Nov 2006 20:15
#89902
it can be done, just takes custom motor mounts. the 650 and 750 motors are interchangable, as are the 900 and 1000, and the 650/1000 has been done, as well as the 750/1000, so your swap should be the same deal.
have a look at this
Scott
Post edited by: 77KZ650, at: 2006/11/05 23:17
  • Popeye
  • Popeye's Avatar
06 Nov 2006 05:53
#89935
sapper7 wrote:
Yes, I have a 4 cylinder 750 in the bike at the moment. The engine runs great but having problem with the starter gears in the gearbox. Replaced the starter and still having problems grinding gears. If I have to pull the engine and look for parts I was thinking of replacing the entire engine with something larger.<br><br>Post edited by: sapper7, at: 2006/11/05 18:27
Just replaced the starter clutch on my 750, it's about a three hour job done with engine in frame through the bottom of the engine with the clutch, exhaust and the LH drive cover removed.
