Valve to Valve clearance test
- mark1122
- Keep twisting it
05 Nov 2006 08:07
What is the best way to check the valve to valve clearance,{eng on bench}so when I degree the cams I can be sure how far I can go without worries?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
Re: Valve to Valve clearance test
05 Nov 2006 08:15
clay in valve notches on pistons always works for me;)
- BSKZ650
05 Nov 2006 15:53
I think you are talking about piston to valve clearance when you degree the cams? if so as a rule of thumb you dont want to advance or retard anything more than 6 degrees, if you move that much you need to change cams, you should not have any clearance problems unless you have some high compression pistons installed
77 ltd1000, current rider
76 kz900, just waiting
- mark1122
- Keep twisting it
06 Nov 2006 16:57
no I am talking about valve to valve.I have over size intakes. and if i change the lobe center they could hit.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
06 Nov 2006 17:32
ah,the rest of the story!
i dont to be the one to screw up this one,better wait for APE JAY or one of the other geniuses!
- larrycavan
06 Nov 2006 18:18
The answer is posted over on Cyclemadness.....
Ooops....is that a bad word around this place?
- steell
06 Nov 2006 18:31
larrycavan wrote:
Not that I'm aware of, there have been rumors to the contrary, but they were simply rumors.
And I'm reasonably certain that I would know
I, and I think most of the other Moderators, are members there also (along with the 1000's of other sites that I am a member of).
Post edited by: steell, at: 2006/11/06 23:25
- larrycavan
06 Nov 2006 18:53
steell wrote:
Cool....I just didn't feel like typing it again...probably could have copied and pasted though...
larrycavan wrote:The answer is posted over on Cyclemadness.....
- mark1122
- Keep twisting it
07 Nov 2006 20:45
Thanks Larry.I read your thread and appreciate it very much. I just like to get lots of input. Sometimes people do things different ways.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- APE Jay
07 Nov 2006 21:41
Here is a trick we have been passing on to KZ guys for years. If you are running big valve heads and/or long duration cams that might cause valve to valve issues when timing the cams;
Get an old stock cam and have the lobes ground off. Then when degreeing the cams, put the lobless cam on one side while you degree the other, then swap them around and put the lobless cam on the other side while you then degree the other cam. This way, the motor never turns over with all the valves opening until the cams are in time.
You can check the valve to valve by using a piece of 1/8th dead soft solder. Put it down the spark plug hole and maneuver it to get between the valves. Turn the motor over. If the valve don 't touch the solder, you are oK. If it does, it will mash the solder, then you can take it out and measure the flat part and know what the valve to valve is.
Jay
Post edited by: APE Jay, at: 2006/11/08 00:43
Jay
- mark1122
- Keep twisting it
07 Nov 2006 21:57
Jay isnt it past your bed time?:laugh: thats a great help.thanks. what should the min clearance be?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
