1978 kz 650 b to 750
- odl666
30 Oct 2006 10:07
I was wondering if i could use the jugs off of my 1982 kz750 ltd and put them on my 650b motor using the 650 head and cams. I also have the 750 cams and head but would rather use my 650 head.
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
1979 gs750e
- mariozappa
Re: 1978 kz 650 b to 750
30 Oct 2006 10:21
This might help answer some questions
kzrider.com/component/option,com_joomlab...mit,20/limitstart,0/
1977 KZ650C1
and the KZ650/KZ750 Conversion
- odl666
30 Oct 2006 10:45
Thanks for the page. all that goes into a lil more detail than i need. Byt any chance does anyone know if i can just straight up put some 750 jugs and pistons on my bike with a 650 head and cams? I know i will have to bore out the casings a lil bit. Will i have to do an other major mods, also if the 650 cams dont work i do have some 750 cams.
1979 gs750e
1979 gs750e
- OnkelB
30 Oct 2006 12:05
No, you can´t use the 82 750 jugs on a pre-81 650 bottom end, the cam chains are different and you can´t use the pre-81 cam chain idler sprockets with the 82 jugs. This thread explains why:
kzrider.com/component/option,com_joomlab...ew/id,87924/catid,2/
77 KZ 650 B1, 82 GPz 1100 B2.
