GpZ750 into a KZ650
- medic24
GpZ750 into a KZ650
28 Oct 2006 11:05
Has anyone put a GpZ750 engine into a KZ650? Any particular problems? How was the end result?
Thanks
Thanks
- wireman
- steell
Re: GpZ750 into a KZ650
28 Oct 2006 12:37
79 KZ650SR in my garage with a 83 GPz750 motor in it right now
You will either have to switch the rear sprocket to a 630 or have a custom front sprocket made if you use a 83-85 GPz750 motor though, the 83-85 GPz750 uses an offset front sprocket.
There are other things you need to do also.
- medic24
- steell
28 Oct 2006 13:11
medic24 wrote:
80 GPz750 motor? I think 82 was the first year. A 1980 KZ750 four motor would be a little easier to put in a 650 though.
Thanks steell, I'm lookin at an 80 engine.
- medic24
28 Oct 2006 15:47
DOH.... yep, it's an 82. Any particular fit problems? Different engine mounts, etc?
Thanks
Thanks
- steell
28 Oct 2006 17:32
Just a matter of spacers and adapting the charging system and electronic ignition, no offset sprocket required so it should be pretty easy.
- medic24
- steell
29 Oct 2006 06:33
The 650 stator can be used on the 750 motor, then it's just a plug in operation. I'm not sure if the 750 reg/rec will plug into the 650 harness, we used a 83 GPz750 motor and it may be different than the KZ750 reg/rec.
The 750 igniter can be mounted on the 650 fairly easily, that way you have a reliable electronic ignition for low cost.
- medic24
29 Oct 2006 07:37
Thanks for the info, now we'll see what this winter brings
