motor - '82 in a '79
- ericross3
17 Nov 2005 18:36
Can I put a '82 kz650 motor in my '79 kz650. If so, will there be any unexpected inconveniences I will have to look forward to?
- MkII
Re: motor - '82 in a '79
18 Nov 2005 09:20
23 views and no replies.....Anyway, start by doing some careful measurments of both engines (assuming you have both) if not then unless you can find someone who's done it, give up. IF you have both, measure up the mounting points and compare.. it should be straight forward to determine if it's gonna be a drop-in or you have some fab work ie motor mounts to do. good luck.
1977A1 current project: 1075, Web cams, VM29's Cavanaugh massaged head, Z1 crank
1979A3A Parked in 1986 left in shed
Phx,Az
Phx,Az
- Mellvis
18 Nov 2005 11:08
Should be a direct bolt in. The 82 will have electronic ignition where the 79 will have points. I don't know if the charging components will be the same. You should be able to use the ignition system and charging system components from the 79 engine on the 82 engine if you don't want to uprade.
Let us know what happens.
- ericross3
19 Nov 2005 07:43
Thanks for the reassurance. I thought it would probably just drop in. I'll post picures and what not when it's done.
