Engine Forum
Engine forum is a tech forum for "Engine" topics.
KZ1000 Valve Cover Leaking..
  • floridamba
  • floridamba's Avatar Topic Author
23 Oct 2006 13:53
#86563
I ride a Concours fulltime and my 82 1000 LTD part time. I recently adjusted the valves and tuned up the LTD and it was running fine. I did not change the oil at the time of the tune-up.
I changed the oil a week later with Valvoline 10w-40 and my valve cover started to leak! It's a small leak at the left front corner of the valve cover. I can't tell exactly where it's coming from.
I guess it's time to take out those rubber pieces and seal them because the gasket is already sealed.
I'd appreciate any observations, recommendations, etc.
GoGators
  • wireman
  • wireman's Avatar
Re: KZ1000 Valve Cover Leaking..
23 Oct 2006 14:28
#86581
id clean them up really good and use a little clear silicone on them,go ahead and drop new valvecover gasket on there while youre at it.;)
  • cary
  • cary's Avatar
23 Oct 2006 15:46
#86617
that's not a problem! it's a feature!
all kz's come with an automatic chain/pantsleg/boot oiler.
I am suspicious of any kz that does not leak oil at the cam plug / valve cover area.
  • RonKZ650
  • RonKZ650's Avatar
23 Oct 2006 16:13
#86625
The cam end plugs can leak, that's always a problem. I recommend Yamabond #4 on them. No reason the gasket itself should ever leak, and no need to use any sealer on it. If it's leaking you probably got a piece of debrie from an old gasket or something on the mating surface.
  • floridamba
24 Oct 2006 03:37
#86793
I sealed the gasket and didn't do the cam plug as it's different than the ones on my 1980 model. Oh well...something to do tonight!
