  • Page:
  • 1
  • 2
aloy polishing 20 Oct 2006 05:38 #85668
  • jimmybon
  • jimmybon's Avatar Topic Author
  • Thank you received: 2
I'v just don up the clucth on the z650 hibrid, new cable, cleaned and greesed the cable tranfer race, and also repaced the dampener rubbers in the clutch basket. Big job that one.
I'v decided to go back to the oringinal KZ650 clutch cover on the GPZ bottom end. No problem, all i'v got to do is plug the old kick start hole.
Do i just stick a made up shaft with flange into the hole from outside or inside using the same shaft seal
or take the seal out and press an interference plug with a flange straight in.
any idears
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
aloy polishing 20 Oct 2006 05:44 #85670
  • jimmybon
cover almost completed recantly
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
aloy polishing 20 Oct 2006 06:04 #85675
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
  • Thank you received: 11
I thought I saw an aftermarket plug made up to block off the kicker shaft hole but I can't remember where I saw it.
My question is since you are running a GPZ bottom end can you tell me if the GPZ 750 bottom end has the hole machined in the cases to use the 650 clutch pushrod set up? I have a 750 GPZ engine that I want to swap into a 79 KZ 650 B the GPZ engine uses the clutch setup on the cover. I need to know if it is possible to just use the 650 covers and pushrod or do I need to use the GPZ clutch set up?
Not trying to hijack your thread but I figure you might have the answer having already done this swap.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
aloy polishing 20 Oct 2006 08:07 #85691
  • wireman
  • wireman's Avatar
  • Visitor
ape sells a kit for 900-1000 im not sure about 650 though;)
aloy polishing 20 Oct 2006 09:18 #85705
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
  • Thank you received: 29
If it were me, I'd just use a clutch cover from a newer ('80~) KZ650 like the CSR or LTD that didn't have a kickstarter. I see them on eBay all the time, some even chromed! B)
That way you can eliminate the hassle of trying to fab some kind of plug to fill the kickstarter hole (which IMHO would probably look really crappy against a freshly polished/chromed cover), and not have to worry if that plug will ever leak.
That's just me though. I'm kind of lazy like that. :silly: :side: :whistle:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
aloy polishing 20 Oct 2006 09:43 #85711
  • The Gringo
Yeah but keep in mind where he is located, the shipping costs would be huge.
Ape must be where I saw that plug, they should be the same between the 1000 and 650.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
aloy polishing 20 Oct 2006 15:23 #85805
  • jimmybon
thanks wirman, do u know how there held into the hole?
theres no problem with me making the plug, its just what design i use
I have plenty of 7 series aircraft aloy available
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
aloy polishing 20 Oct 2006 15:35 #85807
  • jimmybon
It all started with me wanting to have a rubber mounted bottom end, hense the gpz750 crank cases with paint removed. Then I still wanted the look of the bike to be like a kz650 trying to look like a z1900. sounds a bit weard but that was the plan
So I'v got the original drive sproket cover and now the original clutch cover
I have to go to work now but will reply later re how to do the selector cover conversion
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
aloy polishing 20 Oct 2006 22:42 #85912
  • geerbangr
  • geerbangr's Avatar
  • Thank you received: 4
I'm curious to know how the hell you got that high luster shine on that cover !!!! :whistle:
1978 KZ 1000
I go by Jason
aloy polishing 20 Oct 2006 22:54 #85914
  • Six9GS
  • Six9GS's Avatar
  • Thank you received: 0
My KZ650 covers were pretty crappy looking when I got my bike. I used good ole mother's aluminum polish and patience and they have developed a really nice shine to them. I really like the mother's aluminum polish. Removes crude from just about ANY none chrome surface. I've used it on fork tubes, carb bowls and tops and engine covers. It will clean up the casings and heads but doesn't really make them shiny. That's my $0.02
Peace out all!!!
aloy polishing 21 Oct 2006 00:43 #85917
  • jimmybon
I first filed all the gougers and heavy scratches out with varies files. Then emery cloth or glass paper from a 250 grade all over, that then shows up all of the smaller imperfections so then a little more filling and finish with 400, 600, 1200 grade wet sandin paper. The final finish in done on a buffing wheel on the bench grinder, using white stick polish for aluminium.
Once you take to a cover with a file there's no turning back. That cover did,nt look too bad before i started, then appox 4 hours work with 30 years experiance in metal trades but its the only way of getting that finish
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
aloy polishing 21 Oct 2006 01:12 #85918
  • jimmybon
kawasaki decided to release a shaftdrive model z750GT in the early 80s. To do that they reshaped the crankcases at the point of the gear selector cover mating surfaces larger, to accomadate the bevel gears and shaft drive cover. the bolt holes stayed the same That became the new shape for chain drive models as well
So I added the extra meat through alloy welding to the z650 cover to match the new mating surfaces
Another way would be to add the hole and seal for the push shaft to the gpz cover. You could do that by building up weld to that area on the insideof the cover and then machine the cover to fit the seal, and to get the exact centre point to machine u would have to make a say 2" shaft the smae dia as the original with a point machined at one end then bolt the welded cover on then using the clutch push rod tap through the gear shaft to the pointed shaft to mark the referance point
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • Page:
  • 1
  • 2
