swapping heads
- zippoman
swapping heads
19 Oct 2006 14:10
would there be any problems swapping heads from a 1980 to a 1977 kz 650? Thanks
- reborn650
Re: swapping heads
19 Oct 2006 14:46
Hey Zippoman. You should be ok with the head swap as long as you keep the complete cam chain assembly and tensioner from the '77650's roller chain assembly. Should be just a bolt on job.
1977Kz650 Custom - 810 big bore with lottsa go-fast goodies tucked away inside.
-1998 Jeep TJ Wrangler 4.0...
- kawsakiman
Re: swapping heads
19 Oct 2006 14:49
got to plug off the emissions from the exhaust side also doesn,t he?
- reborn650
Re: swapping heads
19 Oct 2006 16:15
Use the 1977 650 valve cover and you should be good 2 go.
-Colin Firth
-Colin Firth
- kawsakiman
Re: swapping heads
19 Oct 2006 16:32
but won't the exhaust still blow into the cover? does he still have to pipe plug or fill the emission ports that come from the exhaust ports into the clean air-reed valve set-up? i know ape makes a block off plate for this head. i got the same head and i was wondering the same thing.i thought 80 heads had that. can we block them then use our old valve covers?
- zippoman
Re: swapping heads
19 Oct 2006 17:23
Thanks for the replies, will the cams work ok with my cam chain?
- steell
Re: swapping heads
19 Oct 2006 17:51
zippoman wrote:
I don't know why not, both 77 and 80 KZ650's have a roller cam chain.Thanks for the replies, will the cams work ok with my cam chain?
