'76 Kz900 Crankshaft Bolts
- 9sec1000
19 Oct 2006 12:33
I'm trying to put together my '76 900 and I've ran into a crank bolt problem. The guy before me ran to the local hardware store bought some metric bolts and threw them in it. The Crank has 12 bolts holding it in, 8 go through both the lower and upper cases and 4 go through a "Crank Cap" into the upper case. I was able to locate the correct bolts for the 8 that go thru both cases. Unfortunately, I can't find the 4 bolts that go thru the cap and into the upper case. My smart parts doesn't even list the cap in any diagrams! If youy guys could help me out with some part numbers or correct lengths for those 4 bolts I would REALLY appreciate it. Thanks
- JR
Re: '76 Kz900 Crankshaft Bolts
19 Oct 2006 19:08
Afraid I cant help with your bolt question - I'm sure someone else will be along who can - but I'd sure like to see a bigger pic of that bike of yours.
- wiredgeorge
20 Oct 2006 06:00
The four bolts that hold the crank cap are the same length as the other eight crank bolts. These are 8mm x 1.25 pitch. I can get the length if you need it.
- 9sec1000
20 Oct 2006 07:42
Unfortunately My 8 other bolts are not all the same legnth; 2 are 81mm, 2 are 95mm, and 2 are 72mm! so if you could get me the length I would be grateful. JR I'm not to familiar with the site but I'll try to post some bigger pics of then and pics of what it looks like now- ALOT OF PIECES!
- wireman
20 Oct 2006 08:05Please Log in or Create an account to join the conversation.
- wiredgeorge
20 Oct 2006 13:06
wireman, The pic of the stud was not what the fella was asking about... in any case, I didn't have any cam cap bolts laying around... thought I did. My memory told nme that all the 8mm bolts were the same length but I was wrong about that. When I pull the case bolts, including the cam cap bolts, I put them on a cardboad card with holes in it to keep locations... on some of them I write the actual bolt size and length but in this case, I didn't... (I checked). Sorry.
Update - Believe I found some crank cap bolts... 8mm x 72mm and 1.25 pitch - Like I said, I THINK they were from a crank cap.
Post edited by: wiredgeorge, at: 2006/10/20 20:19
- hillclimber
22 Oct 2006 18:45
Buy the APE crank stud kit ..will be stronger than the stock bolts..around 50 bucks.......
- wireman
22 Oct 2006 19:38
hillclimber wrote:
that was my point,especially with a namelike his!:evil:Buy the APE crank stud kit ..will be stronger than the stock bolts..around 50 bucks.......
- donthekawguy
22 Oct 2006 20:47
I would also go with the APE kit. I only want to build my bottom end once.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- 9sec1000
24 Oct 2006 11:19
I've already got the APE HD stud kit and crank cap brace. I'm talking about the bolt that hold the crankshaft in. not the studs that hold the cylinders and head on. But, thanks to you guys I was able to locate my last 4 bolts and they are 8x72x1.25 Thanks everyone.
- wireman
24 Oct 2006 19:22
9sec1000 wrote:
they make case studs also;)I've already got the APE HD stud kit and crank cap brace. I'm talking about the bolt that hold the crankshaft in. not the studs that hold the cylinders and head on. But, thanks to you guys I was able to locate my last 4 bolts and they are 8x72x1.25 Thanks everyone.
