Bore Diameter For 1977 Kz1000?
- reborn650
16 Oct 2006 19:32 #84832
by reborn650
-1998 Jeep TJ Wrangler 4.0...
Bore Diameter For 1977 Kz1000? was created by reborn650
My friend ( a fellow member on Kzrider) is having some issues with the piston rings on his 1977 Kz1000 LTD. We want to measure the bore of his cylinders and would like to have the exact factory specs to compare. It wouldn't hurt to also have the exact measurements of the first overbore for factory pistons.
Can anyone help with this question?
1977Kz650 Custom -810 big bore with lottsa go-fast goodies tucked hidden inside.
- inline4
- Thank you received: 1
16 Oct 2006 19:52 #84835
by inline4
Replied by inline4 on topic Bore Diameter For 1977 Kz1000?
Now I'm not going to bet a months pay, but I'm pretty sure the standard bore for the 1000 engines is 70mm.
Hope this helps.
Hope this helps.
- 77KZ650
- Thank you received: 7
16 Oct 2006 19:53 #84836
by 77KZ650
07 MDP Rookie of the Year
Replied by 77KZ650 on topic Bore Diameter For 1977 Kz1000?
If Im reading the right part of the wiseco page, its 70mm(1015cc), the next size they list is 71mm(1045), then 72(1075) and 73(1105) to go bigger requires resleeving
link
not sure if the kaw oversized pistons follow the same jumps in size or not
Scott
link
Scott
- Mcdroid
- Gone Kwackers
- Thank you received: 496
17 Oct 2006 03:03 #84877
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic Bore Diameter For 1977 Kz1000?
Colin:
The manual states 70.0 (like inline4 said). Specifically, the manual lists 70.0 - 70.019 as standard with the service limit being 70.1
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- larrycavan
17 Oct 2006 04:11 #84881
by larrycavan
Replied by larrycavan on topic Bore Diameter For 1977 Kz1000?
KZ 900 Bore / Stroke - 66 x 66 [mm]
KZ 1000 66 x 70 [mm]
OEM Pistons go in .5mm over size increments.
What's the problem with the ring end gap?
- vegasjetskier
17 Oct 2006 10:36 #84953
by vegasjetskier
Replied by vegasjetskier on topic Bore Diameter For 1977 Kz1000?
larrycavan wrote:
Should be 70 X 66.
Should be 70 X 66.
- APE Jay
17 Oct 2006 17:04 #85047
by APE Jay
Replied by APE Jay on topic Bore Diameter For 1977 Kz1000?
vegasjetskier wrote:
Yeah.. That 66 X 70 motor would be a KZ958:P
Jay
Should be 70 X 66.
Jay
- larrycavan
17 Oct 2006 17:24 #85051
by larrycavan
Yep...I was definitely not very awake this morning when I posted...I hate it when that happens...
