Redneck oil pump
- JAILBAIT
Redneck oil pump
16 Oct 2006 08:52
has anyone ever mill'd the oil pump cover to create more oil pressure? how much did you take off the pump and how much pressure did you pick up ?
- kzwolfsr
Re: Redneck oil pump
16 Oct 2006 10:54
Well Jailbait, your bike is designed to pick up a certain amount of oil at a time, plus designed in a certain way so it can pick up oil. Also too much oil distribution can cause bubbles in the oil, but do what you want dude. Tell me your results
Original man of the Caribbean
- arobsum
- 77KZ650
16 Oct 2006 13:19
I believe that Jeff Saunders did something very similar on one of his turbo bikes to ensure lots of oil. I think the process involves using a piece of glass, and valve lapping compound to tighten up the clearences to make the pump more efficient
07 MDP Rookie of the Year
- wireman
16 Oct 2006 16:14
this is what i was referring to as blueprinting an oil pump sometime back,yes it works.
- JAILBAIT
17 Oct 2006 12:42
Yeha I remember we talked about it wireman, but how much do I need to mill off is the real question. I can machine it I just need to know how much to take off
- wireman
17 Oct 2006 19:51
measure height of gears,then measure depth of housing plus gasket.adjust accordingly;)
