Oil gallery adapter
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: Oil gallery adapter
15 Apr 2008 21:17 - 15 Apr 2008 21:50
#206806
OK - Time for an update. I know it's been a LONG time, but I finally tried to install the oil pressure gauge kit that I bought and the bushing threads are wrong. I think I was right all along and they are indeed 1.5mm, not 1.25mm. The threads on my plug are visibly spaced farther apart than the ones on the bushing I bought. The plug I removed goes in easily by hand and the new bushing will not.
Can anyone confirm the thread size and tell me where I can get a bushing? This is for the 79 KZ1000 A3 MKII.
Thanks
The Kaw List:
Last edit: 15 Apr 2008 21:50 by 79MKII.
  • renobruce
  • renobruce's Avatar Topic Author
15 Apr 2008 21:33
#206810
I have learned that some of the Kawis have 1.25 threads, some have 1.50 threads. You have the wrong adapter. I sent you an email requesting your address, and I will send you the right adapter, no charge. Sorry for the mix-up.
78 KZ1000
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
15 Apr 2008 21:53
#206813
Got the email - Thanks very much for taking care of that! I was hoping that my motor wasn't some one-of-a-kind oddball or that it wasn't tapped at one time. I'm glad to hear that a simple bushing swap will take care of it. The fittings and the guage look awesome! Real nice stuff. Can't wait to install it.:)
The Kaw List:
  • Bluemeanie
  • Bluemeanie's Avatar
16 Apr 2008 06:22 - 16 Apr 2008 06:23
#206842
How about something like this?
Also noted in description: "Attention: With all liquid filled gauges, you will get a false reading, or "zero" reading, on the gauge when the engine is running at operating temperature and the oil inside the gauge is hot. Pressure readings must be taken when the gauge and engine temperatures are relatively cool."
Last edit: 16 Apr 2008 06:23 by Bluemeanie.
  • renobruce
16 Apr 2008 07:06
#206850
Yes, that's my kit. They work great! :)
78 KZ1000
  • tuxedotito
  • tuxedotito's Avatar
16 Apr 2008 08:02
#206860
79MKII wrote:
renobruce wrote:
79MKII wrote:
I just confirmed the thread size as m14x1.5. Now let the search begin!!:P<br><br>Post edited by: 79MKII, at: 2006/12/10 15:46
Nope, it's 14mm x 1.25
Could the MKII be different? My 14mm x 1.5 die fits perfectly. No slop at all.
This is a picture of a VDO electric oil temperature sensor installed in my '81 GPz1100(1170 actuallyB)) and it is M14x1.5, no doubt about it. It fits perfectly because it is the correct thread type and size.
M14x1.25 is fine pitch, and also the Spark Plug thread type and size used in KZ's; check the NGK website. Try threading a Spark Plug into your oil gallery hole and see what happens:lol: :lol: If it happens to fit, then you have M14x1.25; either way you will know for sure. Best of luck with your project!
1981 GPz1100, Wiseco 1170 Kit, BS34 carbs; #40 Pilot and #140 Main, UNI Filters, APE main and cylinder studs, DYNA S, DYNA Coils, and lots of hours. Working towards Megasquirt/Turbo one day!!!
Ft. Lauderdale, FL
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
16 Apr 2008 10:44
#206906
Good idea with the oil temp set up. Thanks for the tips.
The Kaw List:
  • tuxedotito
16 Apr 2008 12:01
#206914
You are welcome, the sensor is actually for a VW Bug, and also some Porche applications as well. The thread specification was the same so I bought one just to see if if would work, and it does! I also bought a VDO electric gauge, 0-300 degrees, and it functions perfectly. I got both together on flea-bay, new, about $80 bucks or so grand total, and they are very plentifull. Any VW performance parts house or VDO distributor would have them. I am fabbing-up an aluminum instrument panel with all VDO. My first ever "project" many years ago was a '68 Beetle and I still love them:) If you are building up an old Beetle, you use VDO:lol:
Best Regards,
Todd
Ft. Lauderdale, FL
  • renobruce
16 Apr 2008 12:36
#206927
You can also put an oil temp sensor on the oil drain plug. I'd like to set up one that way since it has an oil pressure gauge in the oil galley port. Does anyone know what the thread size is on the Kawi for the drain plug?
78 KZ1000
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
29 Apr 2008 10:59
#210047
Hey Bruce - sent you an email the other day but haven't heard back. Have you had a chance to send the correct adapter? Send me an email when you get a chance. Thanks
The Kaw List:
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
03 May 2008 22:21
#211012
Calling Mr. Reno Bruce -
Reno Bruce, please come in -
Are you out there Reno Bruce? -
(silence...)
:P
The Kaw List:
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
07 May 2008 10:12 - 07 May 2008 11:10
#211792
3 weeks and still no part and no answer to several emails. Has anyone heard from this guy lately? He still has the gauges listed on eBay. I tried to contact him there so we'll see if he answers.
UPDATE:
OK - heard from his wife through my eBay question. Bruce is out of town on a family emergency. Good thing I didn't totally panic and send a profanity-laced tirade. :blush: I'm good for about 2 weeks and then I start to get anxious. I need more patience, I guess.:laugh:
The Kaw List:
Last edit: 07 May 2008 11:10 by 79MKII.
