Oil drain bolt from hell... Got it out!
- DasTeufel
Re: Oil drain bolt from hell...
06 Dec 2005 07:41
If you don't want to spring for a new pan, you can remove the pan, go down to your local parts store, pick up an oversized drainplug, and drill/tap for the new plug. There are also self tapping drainplugs on the market, I've had mixed results with those on cars.
2009 KTM 690 SMC
2008 Kawasaki Ninja 250R
2001 Suzuki GSXR 750
Wildomar, CA
Wildomar, CA
- MDawnz1
06 Dec 2005 13:40
DasTeufel wrote:
To fix it right you have to pull the pipes then the pan,
Get a new mag drain plug and take it to a GOOD auto machine shop and have an insert installed , $20 max.
OH, PLEASE DON'T do that! Oversize and self tapping drain plugs are for STEEL oilpans.If you don't want to spring for a new pan, you can remove the pan, go down to your local parts store, pick up an oversized drainplug, and drill/tap for the new plug. There are also self tapping drainplugs on the market, I've had mixed results with those on cars.
1974 Z1a, still 903
