KZ400/400
  • bobarama
  • bobarama's Avatar Topic Author
KZ400/400
11 Oct 2006 12:51
#83492
Just checking to see if I have this right: I have a 77 KZ400 S3 that has horrendous blowby and low compression. If I read correctly, I can put KZ440 pistons and jugs on ot and use my 400 head and carbs. is that correct? Any certain years of the 440 better for this swap than others? Thanks, Bob
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: KZ400/400
11 Oct 2006 14:41
#83513
Whoa! That's an intersting way to fix a compression problem! ;)
I believe it has been done before, but I have no idea how. Obviously you would have to make sure all the oil passages meet up, and I know that the later engines had an external oil passage...
Have you checked the piston rings? Maybe they are broken or something? That might be an easier fix...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
