Manual Cam Chain Tensioner, good or bad?
- markmeinteil
11 Oct 2006 01:02
I know very little about how well a manual cam chain tensioner would work for everyday use. Is there any reason not to use one? Do you have to continually make adjustments to it?
Any input would be appreciated.
- Samwell
Re: Manual Cam Chain Tensioner, good or bad?
11 Oct 2006 02:51
If you look after it, a manual tensioner should do fine. I've had a couple of bikes over the years with these and there's been no trouble. In fact I think that APE makes a nice one for our KZ's. They'd probably be able to give an good estimate on maintenance intervals too.
Sam
Sam
- wireman
- steell
11 Oct 2006 04:23
The KZ750 twins have a manual tensioner stock.
But it's on the front of the motor and easy to get access to adjust it.
- JR
11 Oct 2006 05:28
I had an APE tensiner n mine but took it off recently when I just could'nt get it set right. I might try it again next season.
kzrider.com/component/option,com_joomlab...id,2/id,62350/#62350
- markmeinteil
11 Oct 2006 23:05
So how are you supposed to check it? Do you turn in the nut until it's tight, and then back it off some?
- Lorcan
- Speed Loony
12 Oct 2006 04:14
I must say I've never had any trouble with stock tensioners backing off, but I've got an APE manual one on my bike anyway for peace of mind. Turning the motor over forward slowly by hand I screw in the tensioner bolt with my fingers until it won't go any further, then back it off one flat and lock it.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- markmeinteil
12 Oct 2006 12:32
I think I will go ahead and order the manual tensioner then. Thank guys!
- markmeinteil
27 Oct 2006 01:10
An update....
I received my tensioner, and installed it today. Yeah, about 90% of the "bad" noises (rattles) went away! I'm very glad I bought this little device.
Anyone else with the same problem I had should definitely look into the APE manual tensioner.
- kzwolfsr
27 Oct 2006 07:23
i had trouble putting on my tensioner once during my rebuild. The shaft in the tensioner would come out but not go in the tensioner case itself and the little bearing would constantly stop it from going backwards., and even when I tightened the screw the shaft would still shoot out. Well i looked very closely and thought it through andrealised that the washer under the screw head might be stopping the screw from stopping the shaft from moving, so I removed the washer and the screw stopped the shaft from coming out and i installed my tensioner then removed the screw and put the washer back on, simple as that!!
Original man of the Caribbean
- larrycavan
28 Oct 2006 11:56
The side load tensioners like in your turbo held up better than the original KZ automatic tensioners did. Lot's of problems with auto tensioners from Japan. APE has a manual replacement for many motors. Good stuff too.
