compression check
  • TODDZ
  • TODDZ's Avatar Topic Author
compression check
10 Oct 2006 07:02
#83150
What is the proper way to check the compression on my 78 kz650? and what is acceptable ?
  • steell
  • steell's Avatar
Re: compression check
10 Oct 2006 07:10
#83154
Engine warm and all sparke plugs removed with throttle held wide open is the way I do it, others say to remove one plug at a time.
135-150 psi is good, over 100 psi is usually acceptable, under 100 psi normally means there is a problem.
It's a good idea to check/adjust the valve clearances first, as they can have a significant effect on compression.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
10 Oct 2006 07:42 - 03 Dec 2008 12:09
#83164
del
Last edit: 03 Dec 2008 12:09 by JMKZHI.
  • TODDZ
11 Oct 2006 08:19
#83446
Thanks I did the check 175,175,175,175 psi
  • JMKZHI
  • JMKZHI's Avatar
Re: .
11 Oct 2006 08:39 - 03 Dec 2008 12:11
#83451
del
Last edit: 03 Dec 2008 12:11 by JMKZHI.
  • TODDZ
11 Oct 2006 10:21
#83465
I Got 175 psi on each cylinder.
  • TODDZ
11 Oct 2006 10:31
#83469
yes ending numbers did I not check the othe numbers.
  • steell
  • steell's Avatar
11 Oct 2006 15:53
#83524
Well, that's certainly not worth complaining about :D
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
11 Oct 2006 16:12
#83527
On this topic, where can I get a good, relatively cheap compression tester?
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • JMKZHI
  • JMKZHI's Avatar
Re: .
11 Oct 2006 17:55 - 03 Dec 2008 12:11
#83541
del
  • KaZooCruiser
  • KaZooCruiser's Avatar
07 Jul 2007 08:47
#155301
135-150 psi is good, over 100 psi is usually acceptable, under 100 psi normally means there is a problem . . .
I have a question:
If atmospheric pressure is 14.7 (at sea level?), and the compression ratio is 9.5:1 (stock factory spec),
anything above @ 140psi seems indicative of a problem.
  • dnpurdy
  • dnpurdy's Avatar
09 Jul 2007 09:20
#155658
yeah, that's an interesting thought. Can you safely assume that the pressure in the cylinder when the intake value closes is atmospheric?
(1980 KZ440-A1 sold project bike)
(1982 KZ750-N1 still stolen)
1982 KZ750-N1, my only now
