compression check
- TODDZ
compression check
10 Oct 2006 07:02
What is the proper way to check the compression on my 78 kz650? and what is acceptable ?
- steell
Re: compression check
10 Oct 2006 07:10
Engine warm and all sparke plugs removed with throttle held wide open is the way I do it, others say to remove one plug at a time.
135-150 psi is good, over 100 psi is usually acceptable, under 100 psi normally means there is a problem.
It's a good idea to check/adjust the valve clearances first, as they can have a significant effect on compression.
- JMKZHI
Last edit: 03 Dec 2008 12:09 by JMKZHI.
- TODDZ
- JMKZHI
Last edit: 03 Dec 2008 12:11 by JMKZHI.
- TODDZ
- TODDZ
- steell
11 Oct 2006 15:53
Well, that's certainly not worth complaining about
- Biquetoast
- King Jeremy The Wicked
11 Oct 2006 16:12
On this topic, where can I get a good, relatively cheap compression tester?
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- JMKZHI
- KaZooCruiser
07 Jul 2007 08:47
steell wrote:
I have a question:
If atmospheric pressure is 14.7 (at sea level?), and the compression ratio is 9.5:1 (stock factory spec),
anything above @ 140psi seems indicative of a problem.
135-150 psi is good, over 100 psi is usually acceptable, under 100 psi normally means there is a problem . . .
I have a question:
- dnpurdy
09 Jul 2007 09:20
yeah, that's an interesting thought. Can you safely assume that the pressure in the cylinder when the intake value closes is atmospheric?
(1980 KZ440-A1 sold project bike)
(1982 KZ750-N1 still stolen)
1982 KZ750-N1, my only now
