Engine Forum
Engine forum is a tech forum for "Engine" topics.
Kz 750 build up
  • stevieboy96
  • stevieboy96's Avatar Topic Author
Kz 750 build up
08 Oct 2006 14:52
#82648
I am in the process to rebuild a 80 750 4. I read somewhere about building the 750 up to an 810. What is involved in this process. And what kind of performance improvements can I expect. I don't want something totally wild......well......not yet anyway. So any info would be Greatly appreciated.
Steve Willis
  • 77KZ650
  • 77KZ650's Avatar
Re: Kz 750 build up
08 Oct 2006 15:01
#82652
you bore the cylinders 3mm over and use the Wiseco K810 piston kit. it puts compression ratio up to 10.25-1. Get an aftermarket performance exhaust system, individual pod air filters, jet the carbs accordingly, and you will see a big jump in power:evil: for more power (maybe later on)do some light porting, and get a set of bigger cams
Oh and welcome to KZR!
Post edited by: 77KZ650, at: 2006/10/08 18:03
07 MDP Rookie of the Year
  • 77KZ650
  • 77KZ650's Avatar
Re: Kz 750 build up
08 Oct 2006 15:16
#82656
the 650 750 head swap is still debateable i believe. the 650 has smaller combustion chambers 23.7cc and the 750 has combustion chamber volumes around 25cc. smaller chambers = higher compression(more power). but the 750 comes with slightly larger valves which allow more flow. more flow = more power. you see where somebody would relly need a dyno and be willing to try both heads on the same motor to see which combo makes more power
  • stevieboy96
Re: Kz 750 build up
08 Oct 2006 15:20
#82658
thanks for the quick reply. I am also curious about those who made statements about putting 650 heads on. What kind of horse power approx. will I be gaining. I read somewhere that stock is around 65hp I believe.
Thanks,
  • 77KZ650
  • 77KZ650's Avatar
Re: Kz 750 build up
08 Oct 2006 16:39
#82669
hp for a stock 750 is 74, a stock 650 is 64, with all the mods I listed(one more here, get a set of 26mm or 28mm carbs if you are using 24's) you would be in the 100 hp range I would think.
Colin Firth (reborn650) has a very nice 650/750 hybrid bike with an 810cc kit which is very similar to what I am currently building. do a search for some of his posts, lots of great info;)
