What exhaust collars?
- pstrbrc
- '81 GPz 1100 project
08 Oct 2006 12:10
My GPz1100 has a J series head. The header that I took off had the long flange and collars that don't come off, so I need collars and those half-circle inserts for my exhaust system. So, what collars besides J heads (for instance, '82 and later 1000P)will fit? Will Z900? KZ1000? Particular years? Help!
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- wireman
Re: What exhaust collars?
08 Oct 2006 12:16
im thinking you are stuck with j/gpz style split collars they are differant length.i think you can use the outer collars from kz1000 z1/900 outer collars have smaller holes for exhuast studs.
- pstrbrc
08 Oct 2006 12:29
Are you saying that it's the split collars that's my problem? Looking at the collar/clamp/chunk of aluminum that the studs go through Z1 sells a replacement, but they also say that it retro-fits to earlier KZ1000's, so I'm thinking that I could get some of those to work. So the only NEW parts I need are the split collars? Is that what you're saying?
Elkhart, Kansas USA
Elkhart, Kansas USA
- wireman
08 Oct 2006 12:41
yeah ive got some gpz-j style collars ,let me measure real quick.ok about 29mms for the gpz style split collars is what you need.kz1000 outers should be same size z1/900 are smaller.
