(J head)
06 Oct 2006 13:20 #82281 by kz-mtd
(J head) was created by kz-mtd
why is the j head so important? What is wrong with kz1000/900 head:unsure:
  • wireman
  • Visitor
06 Oct 2006 14:29 #82298 by wireman
Replied by wireman on topic (J head)
theres nothing wrong with the z1-kz style head,the j-head just comes with bigger ports and valves right out of box.the only catch to running j-head is your compression will drop about 2 full points with kz style pistons and you have to use a cam chain adapter to use on kz style motor.;)
  • Duck
  • e vica na i sau na ga
06 Oct 2006 14:47 #82306 by Duck
Replied by Duck on topic (J head)
Wireman! Where do you find 30 pin sprokets for the J camshafts?
  • wireman
  • Visitor
06 Oct 2006 14:58 #82308 by wireman
under my bed,ive got an extra set on a big set of cams.;)
06 Oct 2006 16:13 #82323 by racer54
Replied by racer54 on topic (J head)
Anybody know who makes these things? Only thing I can find are 32t cam sprockets for running with a MK11 crank. I wouldn't mind getting a set or two of 30t cam sprockets for my bikes.
  • wireman
  • Visitor
06 Oct 2006 19:35 #82351 by wireman
ill let ya know monday.:whistle:
  • APE Jay
  • Visitor
06 Oct 2006 23:34 #82399 by APE Jay
Replied by APE Jay on topic (J head)
Why use the J cams? Put a good set of cams in. They will be on the three bolt billet and we make the 30t sprockets for them.
The reason we made the 32T for the two bolt J / GPZ cams is that funnybike guys used to use those cams as a turbo cam. Of course, they all ran the big pin crank.
Jay
06 Oct 2006 23:46 #82400 by racer54
One reason I was asking is that my turbo has a small pin crank in it and I was wanting to use a set of GPZ cams in it. Also thought the GPZ cams would be a good all-around cam for small pin 1075 motors on a budget.
  • Duck
07 Oct 2006 07:15 #82417 by Duck
Jay
Jay-
The kits are a bargain. It takes some dedicated scrounging and luck and still spending $200 with APE to come in for total of much less $. If I didn't find the scrounging so much fun, I'd buy the kit!
What is wrong with the J camshafts on the J head with J pistons and block spacer running on a kz? Less lift, but that profile and valve size gets 100+ HP out of the kz1100B2. The manual says the kz1100B2 runs 9.7:1 CR.
-Duck
  • wireman
  • Visitor
07 Oct 2006 07:20 #82418 by wireman
well being the supreme packrat that i am :whistle: ive managed to amass a little of everything,let me see what i have in the boxes when i go box diving.:evil: :P
