How to ?
- kzwolfsr
How to ?
05 Oct 2006 18:29
How do i hook up an oil cooler?Any plans or instructions out there from any kz 650 owners?
Original man of the Caribbean
- 77KZ650
Re: How to put an oil cooler on a 650
05 Oct 2006 18:43
how to
using fittings from Klasmo
make your own fittings instead of buying them from Klasmo
OR use a gpz750 oil pan which cam with oil cooler fittings from the factory. hook up any oil cooler you want to it, or just use the whole gpz setup
Post edited by: 77KZ650, at: 2006/10/05 21:45
07 MDP Rookie of the Year
- rstnick
05 Oct 2006 19:59
I just heard a GSXR oil pan (750?) is a dirrect bolt on. Anyone know if this is true?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- OKC_Kent
05 Oct 2006 20:30
I just happened to receive this rear fitting from a friend tonight at BikeNight. I found a M18 fine thread bolt and a friend offered to machine it. He added the hose fitting I gave him.
I will say it was tough for me to find the M18 fine (1.5mm pitch thread) thread bolt. Once you get into the larger sizes all I could find was a coarse thread. Fortunately I handle the hardware at my job, and the supplier got a freebie sample for me. I sent out a plea on our BikeNight forum in Oklahoma for a machinist to make the part.
Steve Underwood, known here on KZRider as DS2, offered to handle it and it looks great. He made a slight change in the waist section, leaving it a bit thicker. If you notice in the plans you drill an 8mm hole down the center, then turn the bolt down to 9mm in the waist section. That leaves a .5mm thick wall. That seemed a bit thin to me, so Steve made it thicker. I don't think the change will affect the oil flow at all.
It was easy and almost free, but that because I have a couple of great friends. But given the price from Klasmo I knew I could save some money. If you don't have a hardware or machining connection, go with the Klasmo fitting.
Cashion, OK
78 KZ650 B2 85,000+ miles
- letthegoodtimesroll
06 Oct 2006 05:13
I just bought a gpz oilpan and cooler and it is a direct bolt on!
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
