- Thank you received: 16
Oil leak, need help
- kzwolfsr
05 Oct 2006 17:32 #82076
by kzwolfsr
Original man of the Caribbean
Oil leak, need help was created by kzwolfsr
I have an oil leak In the front of my bike on the engine, and trust me guys, its not the tach fitting, I sealed that. It seems to just drain down all the fins from the bottom of the head down. I see some on the studs that hold the head also but that could of been blown there, I dont no. Need help
- wireman
- Visitor
05 Oct 2006 18:01 #82088
by wireman
Replied by wireman on topic Oil leak, need help
take it to carwash and clean it up real good and do an autopsy on it,if you cant see it throw some baby powder around suspect area.
- MDawnz1
- Thank you received: 27
07 Oct 2006 16:43 #82517
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic Oil leak, need help
Take a GOOD flashlight , with the bike COLD ,so you dont stick your face or hands to it ,look for the cleanest spot you can find (like brand new , oil is a great solvent)
Most times it works.
PS For the baby powder trick ,
Ask a lady friend to pick you up a can of powder dry spray anti-perspirant. (It makes your bike smell good too)
Mike
Mike
1974 Z1a, still 903
- MDawnz1
07 Oct 2006 16:44 #82519
by MDawnz1
1974 Z1a, still 903
Mike
Mike
1974 Z1a, still 903
- kawtoy
- Thank you received: 6
07 Oct 2006 16:55 #82527
by kawtoy
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
Replied by kawtoy on topic Oil leak, need help
Head gasket or valve gasket leaking in middle and dripping through the drain holes in the head.
