KZ1075 red line
- Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- wireman
- Visitor
- Exitpupil
- wireman
- Visitor
- APE Jay
- Banned
- Thank you received: 58
What the racers do is figure out the RPM drop for each gear change, and set the shift point to where the RPM will not fall out of the power band on each shift.
Jay
- 79MKII
- Love Them Kaws!
- Thank you received: 43
The Kaw List:
- rattler
- Thank you received: 2
I can only say that what Jay has said is right on. I don't have a dyno, but I have experimented a whole lot at the drag strip with different shift points and my times only got slower if I shifted at 10K or above. I found my quickest times were shifting around 9K or so. I have my limiter set at 10K just in case. If you're revving beyond the peak power curve, there's no sense in it at all. I'd love to put the bike on a dyno some day, but quarter mile times will have to do for now. Good Luck.
i agree with 79mkii, after taking my bike to the track last week i turned my drl red line point to ten and a half grand. you can tell that i started droping off after that. your motor is just used up at that point and is wanting to be be shifted up. a lot of factors pay a roll in were to set the revlimiter. grearing being one. i run a 16f 45r so my rpms realy get up there quick at low speeds. it all depends on the bikes set up.
by the way 79mkII what kind of time you throwing down in the 1/8 and the 1/4?
i was mad last week. it was so cold the night i ran, 50 degrees. i couldnt hook up. i would brake loose till i hit the tree every time. started of launching a 5000rpm and droped to 3500 and still woulnt bite. best i could get was a 7.60 in the 1/8
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Exitpupil
- larrycavan
- Visitor
Is the head ported? What's the CR? valve sizez?
