Slight ticking sound from the right side
- kzmarvo
02 Oct 2006 18:01
After riding my bike HARD about 10 miles(wide open) i have noticed that she has a slight tick coming from the right side when your on the bike. Valve? I know it isnt nothing piston wise but i also know nothing about valves. I am pretty mechanical any ideas what i should do? Adjusting valves on a scale of 1-10 is a what? Any advice is greatly apperciated.:blink:
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
- 77KZ650
Re: Slight ticking sound from the right side
02 Oct 2006 18:55
could it be an exhaust leak?
07 MDP Rookie of the Year
- kzmarvo
02 Oct 2006 19:22
Whats the best way to check for a exhaust leak?
- GPZ1100
04 Oct 2006 19:48
When exhaust on cyclinder #2 was leaking there was no mistaking it. It was night and day difference in noise.
- CptEDIV
18 Feb 2008 11:47
I got the same thing coming from the right side. Sounds like a real light fast tick. I can't tell if it speeds up as the engine does because its so quiet, but I'm assuming it does. The cam chain is in the right side, could it be lose? I did a valve lash adjustment about 6 months ago, and can't remember which valves I added shims to...
If I took the valve cover off, would a new gasket be necessary?
What else could this be, exhaust leak, or spark?
Thanks,
Thanks,
1979 KZ 650 D2 \"Midnight\" blue.
- Bluemeanie
18 Feb 2008 12:19
The cam chain is in the middle CptEDIV, might not be a bad idea to check valve spec's again. But I do know that a KZ in perfect condition (cam chain tension, carb sync, etc) will still make some noise. When I bought my 650 new, the salesman said "if you hear some ticking noises, don't worry about it" I never forgot that. As far as valve cover gasket it's about a 50/50 chance of re use. Let us know...
- CptEDIV
18 Feb 2008 13:02
Gah it is in the middle isnt it.. Its been awhile, not sure what I was thinking. Ok the tick noise is actually coming from the right side engine cover. I just installed new points and condensers a few weeks back, I opened the engine cover and didnt notice anything funny. I didn't use any grease or anything when I put the points in, just bolted them on. Any ideas?
- Bluemeanie
18 Feb 2008 13:53
You need to use a little cam lube for the rubbing blocks! I found that synthedict disk brake lube works great. You may be hearing dry rubbing blocks making noise. Wipe off any old lube and then a very small amount behind each rubbing block so the rotation of the cam carries lube beneith rubbing block. I also wipe a VERY THIN layer on cam. Try it, can't think of anything else that would make noise under that cover. Unless new points are sparking so well you can hear the spark!!! :woohoo:
Post edited by: Bluemeanie, at: 2008/02/18 16:55
- CptEDIV
18 Feb 2008 13:57
rubbing blocks... oh man. those things against the crankshaft bolt... I see. Disc brake lube huh? What kinda damage can this cause? Could I put WD 40 on it and see if it stops?
Thanks for the help.
- CptEDIV
18 Feb 2008 14:57
Yep.. Put some of the lube on and the noise is gone. Thanks a ton.
18 Feb 2008 19:20
Points plates are often fitted with a small felt pad that rubs lightly against the cam. A single drop of oil on the felt pad lasts a long time in keeping the heels slightly lubed as they interact with the cam. That is the purpose for the felt pad when it's part of the backing plate. WD40 is too lightweight and not designed as a lubricant.
Back when using points, never tried either of the other type lubes mentioned (so they might be better).
Am thinking heel blocks gradually wearing down is a primary reason the points gap tends to narrow with usage.
Good Luck!
Good Luck!
- CptEDIV
18 Feb 2008 20:01
Ohhh! Haha, I was wondering what that little felt piece was. I had no clue. Thanks.
