stripped plug...possible fix
- Bob_79KZ
02 Oct 2006 14:22
A friend has a 81 KZ750 and it has a stripped spark plug hole. He was thinking of using a heli-coil or timesert to fix it...
BUT..what if you just drilled the hole out to the next bigger size plug hole? Example: 14mm to 18mm.
Then you'd have no worry about threads coming loose or having to 'glue' in an insert.
Seems much simpler....what do you think?
Bob
Bob
- RetroRiceRocketRider
Re: stripped plug...possible fix
02 Oct 2006 15:22
Yah, you could do that I suppose.
If the head is still on the bike though, you're going to need to figure out how to get all of the metal shavings out of the cylinder afterwards.
Plus, you're going to need to find a spark plug in that new diameter with the same reach and heat range as the old plug.
Installing a timesert or helicoil would take a lot of the stress and work out of it IMHO.
Post edited by: steell, at: 2006/10/02 19:55
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- Bob_79KZ
02 Oct 2006 17:37
Well, in this world of high performance cars and bikes, finding a suitable plug should be a piece of cake.
You're only dealing with 8:5 to 1 compression and regular pump gas. Any plug will light that!!!
Bob
Bob
- 77KZ650
02 Oct 2006 17:44
is there room to go that much bigger? should you worry about getting into the valve seats?
07 MDP Rookie of the Year
- Duck
- e vica na i sau na ga
03 Oct 2006 01:35
The coil kit is cheap and works. My rule is to never remove more metal than necessary. Also you're gonna have a hard time making a nice hole for the 18mm plug with the head installed. Use a collar on your drill bit! Use one size under drill and then finish with the drill for the kit. Also, fill the cylinder with grease with it about halfway up on the compression stroke before you start making chips. This way you'll get all the chips out.
-Duck
-Duck
- jimmybon
03 Oct 2006 04:05
I agree Duck, min meat removed is the best way with the head on. With the heli coil you may not have to drill, just tap vary carefully with loads of grease on it to trap the shavings then clean and go again.
if its a slightly cross thread thread, then a clean up with the original tap could do it. Same thing, use the grease
heli coils don'd need glue, they just screw into the special tapped thread and are way stonger then the original
cheers
cheers
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- BSKZ650
03 Oct 2006 05:04
use the insert it is the best fix.
I dont think you would be able to get the right reach/heat range plug in a larger size ie: 18mm.
77 ltd1000, current rider
76 kz900, just waiting
- OKC_Kent
03 Oct 2006 06:37
Duck wrote:
How do you get all the grease out?
-Duck
Cashion, OK
78 KZ650 B2 85,000+ miles
- Duck
03 Oct 2006 07:10
OKC_Kent wrote:
Turn slowly to TDC and the grease will come out the plug hole
along with the chips. Now if you decided to use your leftover
1950's wheel bearing grease, it might be kind of tough to get
out but some modern light weight "general porpoise" grease will
work just fine.
Same way you got it in:-)Duck wrote:Also, fill the cylinder with grease with it about halfway up on the compression stroke before you start making chips. This way you'll get all the chips out.
-Duck
work just fine.
- OKC_Kent
03 Oct 2006 07:23
Duck wrote:
Mmm, but not the last few tablespoons that fill up in the squish area. I can see all the chips coming out tho.
OKC_Kent wrote:Same way you got it in:-)Duck wrote:Also, fill the cylinder with grease with it about halfway up on the compression stroke before you start making chips. This way you'll get all the chips out.
-Duck
work just fine.
Cashion, OK
- tw..
03 Oct 2006 07:40
Go with the heli-coil. It will work just fine. Load the tap with lots of grease, clean and re-grease often as your cutting the new threads and there is no need to remove the head. I done my head about 8 years ago and have never have a problem since.
tw
tw
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
1978 Z1R
- Duck
03 Oct 2006 07:43
OKC_Kent wrote:
I just rinse with a little kerosene or MMO and turn her over a few more times.
I suspect it's overkill. I can't see Aluminum chips doing much damage anyway.
Duck wrote:OKC_Kent wrote:Same way you got it in:-)Duck wrote:Also, fill the cylinder with grease with it about halfway up on the compression stroke before you start making chips. This way you'll get all the chips out.
-Duck
work just fine.
