Noooooooooooooo!
- cary
01 Oct 2006 17:39 #80996
by cary
Noooooooooooooo! was created by cary
Just fixed my oil leak, gas leak, headlight, gauges, coil voltage, and tightened my chain. Thought I'd throw in a new set of plugs to make it run perfect. Ran like a dream!
10 miles down the road, plug #1 blows out of the head!
won't keep a plug in now, don't know what to do exactly, would prefer a good solution, like a timesert, but I really want to keep riding.
I have a kz1100 donor bike if I need a new head, but the I'd like to keep the motor together until the winter.
Does anyone know of a really good machine shop in the nashville area that will do a timesert without having to pull the motor out of the bike?
- Exitpupil
01 Oct 2006 18:04 #81001
by Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
Replied by Exitpupil on topic Noooooooooooooo!
Yessssss, I have used a helicoil insert kit specifically for spark plugs on cars with Al heads successfully. I put heavy grease on the tap to catch the shavings and used a vaccum cleaner with a tube taped to it to vaccum inside the cylinder just for extra peace of mind.
- Mikes82KZ1100
- Thank you received: 2
01 Oct 2006 18:57 #81016
by Mikes82KZ1100
Replied by Mikes82KZ1100 on topic Noooooooooooooo!
Exitpupil wrote:
Good advice. I would add that after vaccuming, leave that spark plug out and start and run the bike for a few seconds. That way -if- there is a "straggler" piece of shaving it should either blow out the exhaust port or the spark plug hole.Yessssss, I have used a helicoil insert kit specifically for spark plugs on cars with Al heads successfully. I put heavy grease on the tap to catch the shavings and used a vaccum cleaner with a tube taped to it to vaccum inside the cylinder just for extra peace of mind.
- cary
01 Oct 2006 20:34 #81045
by cary
Replied by cary on topic Noooooooooooooo!
Is your shop near nashville?
- MkII
- Thank you received: 1
03 Oct 2006 21:29 #81678
by MkII
1977A1 current project: 1075, Web cams, VM29's Cavanaugh massaged head, Z1 crank
1979A3A Parked in 1986 left in shed
Phx,Az
Replied by MkII on topic Noooooooooooooo!
this is an easy and cheap job to do yourself even if you're not Johnny engine guy....you should be able to buy a kit for under $50 and if you choose to do it yourself, remove the head and do it, why risk getting F.O. in your valve train.
Phx,Az
- 77KZ650
- Thank you received: 7
03 Oct 2006 22:12 #81691
by 77KZ650
07 MDP Rookie of the Year
Replied by 77KZ650 on topic Noooooooooooooo!
would it be a good idea to have the EX valve open and blow air through it into the combustion chamber (and out the plug hole) while its being done? (head on motor)
