- Thank you received: 1
Exhaust flange torque specs
- KZReeder
Anyone know of any specific torque settings for these?
Thanks!
Claude
- Duck
- e vica na i sau na ga
Make sure they are clean.
-Duck
- KZReeder
- bemoore
- Thank you received: 4
Duck wrote:
Will be in the general specifications section for 8mm fasteners.
-Duck
The general specifications section of My Clymer manual doesn't have general torque specs for various sized fasteners. It has specs for several engine and brake fasteners, but NOTHING on any part of the exhaust. Does anyone know the correct torque for the exhaust flange nuts on a 77 650? I did find this general spec: www.dansmc.com/torque_chart.htm
From that I'd use the 8-12 ft-lb spec.
77 KZ650C1 w/Kerker 4-1
- Thank you received: 2098
On the large fours, exhaust stud bolt size was increased from 6mm to 8mm beginning with the '77 model.
Am uncertain about size of '77 KZ650 exhaust stud bolt. If the same 8mm size, would seem logical to apply same torque spec as KZ1000 unless otherwise shown in KZ650 FSM.
Am careful not to over-tighten, and regularly check the nuts. If a nut gets loose, some goo usually appears on the fins around the exhaust port. If a nut gets really loose or falls off, would expect some obvious exhaust leak noise, and then simply tighten or replace the nut. Not a significant problem, at least when compared to a stripped or broken stud.
Good Luck!
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- PLUMMEN
- Thank you received: 104
ditto!:laugh:I just put them tight enough, haha.
- bemoore
Same here, but I've been having exhaust leaks. I tightened them down to 60 in-lbs, which is only 5 ft-lbs, so I thought I was on the low side if anything. If it's the same as Patton's KZ1000, it looks like 43 in-lbs may be the max.I just put them tight enough, haha.
Thanks for the info. Anyone else have a definitive spec for a 77 650?
[quote... been having exhaust leaks....[/quote]
Using new copper exhaust gaskets with a little Permatex hi-temp on both sides should prevent/seal any leaks.
The Permatex also holds the gaskets in place inside the head recess while fitting the header onto the engine.
Good Luck!
[Click on image to enlarge view]
- keith1
- greychur
Paul
1978 Z650C2. Marshall 4 into 1. Newtronic ignition. Otherwise stock(ish).
1979 KZ1000ST. Harris 4 into 1. Dyna S.
Hampshire, England
- RonKZ650
- Thank you received: 240
