clutch not disengaging
- tcbradbury98
28 Sep 2006 05:36
Hi, I have an 83 kz550 c4 ltd. I just replaced the sprockets, rear brakes, and drive chain. Before I did that the clutch would disengage fine. After putting it all back together, when I drop it into first to take off, the gear engages and it kills the engine. I have followed the manual and adjusted the cable several times. It still won't disengage. I had to remove the front sprocket cover to change that sprocket, what did I mess up? I am going to take the sprocket cover off tonight and reassemble again, just looking for tips and advice on fixing the issue, thanks.
- 77Davo650
Re: clutch not disengaging
28 Sep 2006 06:40
You might need to take the sprocket cover off again and make sure the clutch cable is connected and seated properly where it goes into the cover. That happened to me and I just played around with it and adjusting the cable slack and it finally just worked again, but I don't know specifically what I did to fix it. Hope this helps a little.
77 KZ650 C1 (sold)
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
78 kz400 C1 (resto-mod)
78 kz400 C1 (hardtail low chop)
couple of possible project kz's in parts
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
- tcbradbury98
28 Sep 2006 06:44
I did some post searching, and found that I probably re-installed it incorrectly, just as you said. thanks for the help
- tcbradbury98
29 Sep 2006 03:51
Well took it apart last night, had the clutch cable installed off by about 90 degrees, moved it and she works, thanks for all the advice.
