stroker
- kz-mtd
- steell
Lots of cheap Chinese stroker cranks available for V-8's though.
- wireman
- Visitor
- APE Jay
- Visitor
We do a bunch of these for Hayabusas, GSXR1000s, etc.
Jay
- tw..
- Thank you received: 1
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
- steell
No, totally different animalsI'm just throwing this out here but would high dome pistons achieve similar results??
Domed pistons increase compression.
Increased stroke increases displacement.
Increasing the stroke can result in the same, increased, or decreased compression depending upon the rod/pistons used.
Increasing the stroke means the piston moves a longer distance between BDC and TDC.
- kz-mtd
- steell
A question best asked in a PM or e-mail (e-mail is better for Jay).would you or do you the cranks on 76 903 kz motors:unsure:
But you better know what you are doing and give this stroker thing some serious thought.
It "will" require different (probably custom) pistons, and possibly rods as well.
You are still going to have the same heat limitations as you do with an overbore, so you really won't gain anything, but you will spend bucket loads of money
- wireman
- Visitor
- APE Jay
- Visitor
We only stroke plain bearing cranks.
Jay
