Cam Chain Noise?
  • nfswift
  • nfswift's Avatar Topic Author
Cam Chain Noise?
25 Sep 2006 08:49
#79429
Hey guys, I got the Z running but I'm encountering interesting noise when the bike finally warms up and settles down at idle (shy of 1000RPM varying), once the engine slows down enough there is a grinding noise in the top end against what sounds to be the valve cover guide and sometimes it even slows the engine a little/stalls it if it isn't warm enough, is this really bad? I seem to remember reading somewhere that cam chain rattle is a characteristic of the KZs...
Any insight is welcome.
  • firemun59
  • firemun59's Avatar
Re: Cam Chain Noise?
26 Sep 2006 07:28
#79705
cam chain noise is all too common on all makes of 70s and 80s inline 4s.....have you followed the protocol for slack adjustment?
  • pyxen
  • pyxen's Avatar
26 Sep 2006 10:27
#79757
do tell... ??
84 KZ550-F2 LTD
93 ZR550-B4
  • nfswift
27 Sep 2006 07:37
#79984
I think you already know the answer to that question :blush:
All I know is that my auto-tensioner felt pretty tight when I installed it, havn't touched it since.
  • JR
  • JR's Avatar
27 Sep 2006 12:51
#80078
You can pinpoint a noise by using a crude stethescope like big screwdriver - put the blade against the cam cover and the plastic handle up against your ear. If that is indeed the area of noise - and "grinding" does not sound good - then perhaps it's time to remove the cover and have a look ?
