Spun Rotor
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
Spun Rotor
24 Sep 2006 19:03
#79294
I'm haveing trouble keeping my rotor on.I have sheared the woodriff key on the rotor of my 76 KZ 900(SEE SIG BELOW)3 TIMES NOW.There is some scaring on the end of the crank and inside the rotor.The last time it happened(2weeks ago) I used valve lapping compound to try to improve the fit,then cleaned it with brake cleaner and glued it on with green Locktite 609 and let it dry 24 hours.It failed again today while doing a compression test.Can anyone tell me what the best options are here.Should I just go to a stronger locktite,and heat for removal if nessesary later?Is this a common problem?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
Re: Spun Rotor
24 Sep 2006 19:20
#79303
sounds like a really high compression motor,slot end of crank for longer woodruff key.;)
Post edited by: wireman, at: 2006/09/24 22:20
  • mark1122
  • Keep twisting it
Re: Spun Rotor
24 Sep 2006 19:50
#79323
Only getting about 160 psi comp.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
Re: Spun Rotor
24 Sep 2006 20:01
#79327
thats strange,i used to have that problem on my z1 but it had way too much compression though!:evil: it would shear the little halfmoon key off when trying to crank with electric start,so had end of crank slotted for full size keystock which worked till starter shot craps and wouldnt turn it over:P
  • baldtires
  • baldtires's Avatar
Re: Spun Rotor
26 Sep 2006 19:05
#79890
the key dosen't keep it on it keeps it in alignment with the crank
on some engines you leave the key out of the flywheel to change the timing
if you leave the key out and press the rotor on the crank and twist it it should want to grab
the taper on the crank and rotor make a interfearance
fit
is there a lock washer ?is it any good ?
lap it again then heat the rotor, 350 or 400 for 20 min or so the put it on hot with the key, tighten before the crank gets hot
best of luck to ya
  • mark1122
  • Keep twisting it
Re: Spun Rotor
26 Sep 2006 19:20
#79892
Thanks I like that idea ef heating it. If it fails again I'll give it a try but since there is scoring in the rotor Im probably going to have to replace it.Had the same problem with a Yamaha Blaster once ,It had a stepped or offset key to adjust the timeing..
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
