Cam chain riveter tool
  • pstrbrc
  • pstrbrc's Avatar Topic Author
  • '81 GPz 1100 project
24 Sep 2006 05:09
#79141
I'm doing a top-end teardown of my GPz11 because it hadn't run in 16 years, and, anyway, it sounded fun. So, I've found that it needs new cam tensioner blocks and, since it has 34k miles on it, I'm thinking I'll replace the cam chain. Z1 sells the chain (multilink) with a master link, so I won't have to split the cases, but they also sell this funky tool www.z1enterprises.com/detail.aspx?ID=1693
for riviting the master link. Only problem is, $80 for something I'm going to use once (or maybe twice) before I lose it is :pinch: OUCH!!:pinch:
Is there an alternative?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Cam chain riveter tool
24 Sep 2006 05:21
#79143
pstrbrc!
Be also advised that, depending on the cam chain that you buy, it may be endless (but you also buy the master link too) and you'll need the special tool to split the new chain also. I bought the same tool from Jeff and it actually does split chains fairly easily...but I feel your pain (special tools with a single use):)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
