(Another) exhaust question
- EsaPro
20 Sep 2006 17:43
The joint where my headpipes join the muffler leaks. Is there supposed to be some type of gasket or something to seal this? *Can* there be? I have tightened down the collar clamp bolt as far as I can, but it still leaks some when you rev it up. Note the black smudges ahead of the collar in the pic - it blows forward from the joint.
Jim
79 KZ750 Twin (Fun!)
07 Yamaha 1300 (Plush!)
- RomSpaceKnight
Re: (Another) exhaust question
20 Sep 2006 19:06
Maybe try a muffler tape wrap to make tighter seal.
- EsaPro
20 Sep 2006 19:16
I was thinking of that, but wouldn't that stuff melt down and effectively fuse these two parts together? Then again, if I never want to take the muffler off without the pipes (which just might be true if I think about it for a while....)
Jim
- anarki650
20 Sep 2006 19:31
Back when I had the stock pipes on my 77 650 I had leaky seams all over the place until I took the exhaust appart and reassembled it on the bike again. By taking all the pieces appart I was able to reallign all the juncture points and the leaks pretty much went away.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- Shoe48
- Live each day as it is your last
20 Sep 2006 19:50
You can buy a sealer from a parts store that needs to heat set ,, I will say kinda messy though , I have used on Bikes with good results
- rgpbeme
- EsaPro
21 Sep 2006 09:20
Jim
- agawam
21 Sep 2006 20:08
RTV hi temp... a nice bead then let harden for a day, I used it on my H1 chambers, worked good
