kz 1100 clutch adj.
- geerbangr
kz 1100 clutch adj.
11 Nov 2005 16:59
Hey guys,i'm glad i found this site,it looks like alot of wonderful help on here. Now down to the problem,i'm ridin a 85 ltd 1100,far from stock,bike now is a 1260,head work done,425 cams,36mm rs mikunis,dyna ignition.probelem is i just put the bike back together and i put 150 miles on the bike and the clutch started slipping,i tore the clutch down and found a few plates with swollen spots in them so i shitcanned the barnett clutch called the boys up at APE and ordered a new xtra disk clutch from them,i have plenty of clutch at the lever but at about 6 grand the tach spikes up to 8 or 9 grand rapidly which is tellin me the clutch is slipping . tighten up on the clutch a little ??
1978 KZ 1000
I go by Jason
I go by Jason
- hwms
Re: kz 1100 clutch adj.
11 Nov 2005 17:26
What do you mean "tighten up on the clutch a little" ?
If it is slipping I would adjust a little free play in the clutch lever.
Post edited by: hwms, at: 2005/11/11 20:27
- bob_z1
11 Nov 2005 19:57
did the clutch kit you put in have new steel plates too? how about new springs? the power your engine should have may be too much for stock springs.....
- geerbangr
11 Nov 2005 20:31
The clutch kit i installed consists of 10 frictions and 9 steels, new heavy duty springs also, i adjusted the free play in the lever.do i need to tighten up on the clutch adjusting screw ??
1978 KZ 1000
I go by Jason
I go by Jason
- Duck
- e vica na i sau na ga
12 Nov 2005 02:13
There should be no pressure with the lever released. You can shorten the pushrod if you're out of adjustment room.
-Duck
-Duck
