idle nosie
  • kainh
  • kainh's Avatar Topic Author
idle nosie
20 Sep 2006 08:44
#78150
Hi everyone,
New to the forum. I just picked up 79 KZ650. Nice bike, runs good for the age of it and miles (22,000). One question for the experts out there. I have a rattling noise that is coming from the tranny during idle, or at least it sounds like its coming from there. It doesn't seem to cause any bike issues. It accelerates normally and no leaking. Granted, I still need to do a thorough tune up, but wondering if anyone had any ideas or if this is normal. Thanks in advance.
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
Re: idle nosie
20 Sep 2006 09:01
#78152
i have the same on my 750, goes away after like 2000RPM, never did find out why it does it?:(
  • kf6kmx
  • kf6kmx's Avatar
Re: idle nosie
20 Sep 2006 09:18
#78155
kainh wrote:
Hi everyone,
I'm hearing something that sounds like you describe on my KZ750 I just bought... To me it sounds like its coming from the engine though, goes away when you gun it, and only very noticeable at idle... Doesnt have me overly worried (yet), I'm used to hot rod car engines with similar noises, usually from the timing chain, on those its normal and expected, I havent been around enough KZ's to know if its 'normal' on these though :whistle:
  • ltdrider
  • ltdrider's Avatar
Re: idle nosie
20 Sep 2006 09:22
#78157
Sounds like your cam chain needs adjustment. Do you have a manual?
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • kainh
Re: idle nosie
20 Sep 2006 09:46
#78167
a friend is sending me one this weekend. I will verify the cam chain. thanks for the replies
  • RonKZ650
  • RonKZ650's Avatar
Re: idle nosie
20 Sep 2006 10:03
#78172
Also if the carbs are not perfectly synced the primary chain will rattle. That's where the KZ1000 gear grive is a welcome design feature.
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
Re: idle nosie
20 Sep 2006 19:09
#78343
The 650's have a chain driven bottom end that makes noise at low rpm. A carb sync may quiet it down.Mine never went totally silent.
  • ronjones
  • ronjones's Avatar
Re: idle nosie
21 Sep 2006 04:38
#78403
Do you know if this is the same w/a 750 twin? I've been able to get mine running (off and on) and I hear a rattling noise also. Adjusted the cam chain tentioner and it actually seems as if the noise is louder:(
I'm still having trouble keeping it running so I haven't done a carb sync, yet.
  • RonKZ650
  • RonKZ650's Avatar
Re: idle nosie
21 Sep 2006 07:33
#78440
Yes, your's uses a chain, plus there is a chain drive balancer driven off the crankshaft too. Could be one of these rattling. (No balancer on a KZ650, only on a 750 twin).
  • donthekawguy
  • donthekawguy's Avatar
Re: idle nosie
21 Sep 2006 07:45
#78445
I vote for a cam chain adjustment.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • kainh
Re: idle nosie
21 Sep 2006 08:30
#78456
thanks to everyone for their input. I will try the cam chain adjustment first and let everyone know. I was also planning on rebuilding the carbs, so hopefully those two things help out.
  • ronjones
  • ronjones's Avatar
Re: idle nosie
21 Sep 2006 08:41
#78458
Thanks Ron and good luck, kainh.
