84 ZN700 Valve Clearance
- gbxkb
18 Sep 2006 00:42 #77582
by gbxkb
84 ZN700 Valve Clearance was created by gbxkb
So I'm checking out my valve clearances, and I need to know the valve clearance ranges I should be getting. I have the haynes repair manual for the 750cc, and they list two ranges for the valve clearances, one is 0.08-0.18mm for models and another for 0.13-0.23mm. I think the 700 engine should have similar values to a 750, but I could be wrong.
- RetroRiceRocketRider
- Thank you received: 29
18 Sep 2006 01:21 #77583
by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic 84 ZN700 Valve Clearance
I can't locate my clearance listing for the ZN700 right now, but I believe the 750 Spectre is close to, if not exactely the same.
I'd imagine the two diff clearance range listings in your Haynes manual would be for either hot and cold measurements, or intake and exhaust measurements.
- gbxkb
18 Sep 2006 01:40 #77585
by gbxkb
Replied by gbxkb on topic 84 ZN700 Valve Clearance
the two valve clearances appear to be for different engine variations. It says that the GPz models should have the bigger clearances. I guess I'll just stick with the 0.08-0.18. Another question, do the valve clearances normally grow or shrink with wear? I have a few valves with 0.09mm clearance and I was going to loosen them up if the clearance is going to shrink later on.
- jimmybon
18 Sep 2006 04:36 #77601
by jimmybon
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
Replied by jimmybon on topic 84 ZN700 Valve Clearance
from what i know, is that the valve bangs itself against the valve seat billions of times over because of the valve spring, eventualy closing the gap.
I thing the z1900s have softer seats and need more attention
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
