Oil Cooler Question...
- KawasakiBob
14 Sep 2006 16:06
Living in the desert, I try just about anything to cool down the beast.
Here's my question, would a stock oil cooler from an 81 or 82 GPz 1100 fit on my 82 1000J ?
I know they have alot of similarities, but are there any specific mods I'd have to do to make it fit?
There's already the mounting tabs on my frame (I assume its the same as the ELR) for one, but fitting it to the engine is my biggest concern...
- RetroRiceRocketRider
Re: Oil Cooler Question...
17 Sep 2006 23:24
Yes, the oil cooler will from an 81/82 GPz1100 will fit. But you'll need the adapter (Kawi labels it as: "FITTING,OIL COOLER") that the oil pressure switch screws into, since that's where the oil cooler lines mount to on a GPz1100.
The adapter ("FITTING") is located on top of the crankcase, slightly to the right of the cam chain tensioner.
Both the GPz1100 and your KZ1000 J use the same oil pressure switch (27010-1013), so the adapter (and new mounting o-rings) is all that you should need.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- Sandy
- Fly High,Tony
18 Sep 2006 21:52
You'll need 2 adapters for Your J motor,as far as I know.
There's 2 of them on My engine...an inlet and an outlet line to complete the cycle.
1977 KZ1000 A-1
- KawasakiBob
