oil pan problems..
- brianrae33
oil pan problems..
14 Sep 2006 06:27
wondering if anyone has ever had any trouble getting the oil pan off of the bottom of he engine..took every nut off and it will not budge...tapped it rather hard with a piece of wood and a hammer and nothing..??!! i'm thinking the PO had it off and maybe used some sort of sealer on it...i can make out a gasket but this sucker is really stuck..
1982 kz1000ltd
- wireman
- brianrae33
Re: oil pan problems..
14 Sep 2006 18:35
yep...every bolt that is on or even near that f#$%'n thing..
1982 kz1000ltd
- kawtoy
14 Sep 2006 18:47
There is nothing else that could be keeping it from coming off. Check one last time to make sure all the bolts are out. Run your finger along the outside of the pan and make sure you can't feel any bolts. Then pount on it with a rubber mallet. I wouldnt pry on it with anything. Aluminum is too soft.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
