750 hp twin - how much reasonable?
  • CruisingRam
  • CruisingRam's Avatar Topic Author
14 Sep 2006 00:54
#76610
Guy wants to hot rod up his 750 twin, a 1982, and I was wondering if they have an 800 kit, and if they do, what is the most reasonable, streetable HP figure I could count on? What price for key parts?
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
  • steell
  • steell's Avatar
Re: 750 hp twin - how much reasonable?
14 Sep 2006 05:12
#76622
No overbore kits that I'm aware of (other than stock 1mm oversize pistons).
You can send the cams off to have them reground, but other than that you are on your own.
I have heard of a guy that used to roadrace a 750 twin, word is he managed to get 90 hp out of it before he started wiping out bottom ends.
  • weirdooh
  • weirdooh's Avatar
14 Sep 2006 07:45
#76670
what's the stock HP on these things
  • wireman
  • wireman's Avatar
14 Sep 2006 07:55
#76675
define reasonable!:evil: :P i wonder if there is a piston from another motor with same wristpin diameter and location that can be used for an overbore ;) any ideas anyone?
  • mariozappa
  • mariozappa's Avatar
14 Sep 2006 08:02
#76676
I think stock HP is about 55.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • CruisingRam
14 Sep 2006 08:23
#76681
Reasonable to me is able to run tank after tank of fuel with no problems, no blowing up. I didn't say overheat, because overheating up here is not the problem you have down there, with our mild temps.
11-1 compression is not unreasonable up here. Though I don't want silly cams in it, or impossible to start carb set ups either/ I would be very happy with 80hp
  • Sixgun
  • Sixgun's Avatar
14 Sep 2006 08:38
#76688
In the old board SmithGPZ had a 750 he bored larger. I'm not sure what size he made it to though. It's the same bike he put a suzuki swing arm on. Have to look through the archive.
78 KZ750 B3
81 XS650SH
80 XS650G
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
14 Sep 2006 11:14
#76713
Check out what this guy is doing over at the "Lonseome Twin" website...
Here's the link.
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • Flynrider
  • Flynrider's Avatar
14 Sep 2006 16:31
#76763
Kawasaki claimed about 55 hp at the crank. I ran a couple of mine on the dyno when they were young and they turned out around 49 hp at the rear wheel.
  • steell
  • steell's Avatar
14 Sep 2006 19:57
#76834
Smithgpz's 750 twin had either a .020" or .040" over bore, I forget which, and it also had aftermarket Mikuni carbs and Works shocks :)
IIRC, JE Pistons will custom make any piston you like, not cheap though :(
Post edited by: steell, at: 2006/09/14 22:59
  • agawam
  • agawam's Avatar
14 Sep 2006 21:47
#76865
I conversed with a guy on a german site, he told me about putting an exhaust cam on the intake side he says it will give about 65hp, to me this would be about as far as I would go besides a bit of porting and carb work, I plan on a rebuild this winter and have just about all the parts including a new exhaust cam, I would say the twin is a cruisin bike not really made to race although I can pull the front wheel quite easily but the geometry on mine has been altered a bit,I have a couple other bikes for the crazy stuff and the twin is for just riding
