What the heck is this on my oil pump?
12 Sep 2006 20:23 #76248 by kawtoy
The topic should be "Look what this idiot did". The idiot would be me. I was taking the shims out of the buckets to do an adjutment. I was using a pick to pop them out. The very last one was a little hard coming out. It finally popped out... then bounced around the head and right into the cam chain valley. I had to take the oil pan off to get to it. I found it and decided to have a look while I was there. My oil pump was completely covered by this fiber like substance. It looks like fiberglass. It was allowing oil to pass thru cause I had good oil pressure. It came off as one piece and looks like it was made to go over the pump strainer. I had the motor %100 apart a few years ago and I put every last nut and bolt on it so I know it wasn't there before. What the hell could it be? I can tear pieces off. If I try to pull the fibers apart, like if you were to pull a piece of hair into two pieces, it is very strong stuff. It looks to be clear but of course it is oil colored right now. I don't have any clear plastic that it could be. Only thing I can think of is an oil additive maybe. I use Lucas at every oil change and thats it. Any gasket sealer I use is either orange or black, nothing clear. I will add a pic tomorrow. I am scratching my head on this one. Thanks
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
12 Sep 2006 20:50 #76255 by fishbone1
Replied by fishbone1 on topic What the heck is this on my oil pump?
The only think I can think of would be clutch fibers.
12 Sep 2006 21:35 #76267 by kawtoy
Replied by kawtoy on topic What the heck is this on my oil pump?
Nice. I never thought of that. I will have to check that out.
13 Sep 2006 06:29 #76339 by cnyl
Replied by cnyl on topic What the heck is this on my oil pump?
Was the kaw eating some hay?:P Did your wife loose her diaphram?.lol:laugh:
Can't wait to see pics on that one.:P
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
13 Sep 2006 07:55 #76368 by fishbone1
I am curios about this one, also.
13 Sep 2006 10:43 #76419 by hmondo
Replied by hmondo on topic What the heck is this on my oil pump?
I've got to see this too! We're all curious now!
1989 KZ1000 P-8 (Police)
1987 ZL1000
1986 Concours (Project Bike)
13 Sep 2006 10:51 #76424 by eaglemhf
Replied by eaglemhf on topic What the heck is this on my oil pump?
I used three(Tree)-bond once and it was all over the pick-up screen but it was a yellow-ish color.
13 Sep 2006 13:16 #76483 by kawtoy
Here is a pic. Most of the crap you see is just stuff it picked up while on the garage floor. It did have a bit of crap in it but it was little pieces of gasket and what not. It looks like something you peel of the drain after your wife takes a shower.
  • Shoe48
  • Live each day as it is your last
13 Sep 2006 13:25 #76488 by Shoe48
Replied by Shoe48 on topic What the heck is this on my oil pump?
Would this be the remains of an oil filter ?? Or do you live next to someone that no longer likes you and stuffed his hair peice in your Kaw Hmmmm ??? ;) ;)
13 Sep 2006 13:31 #76491 by kawtoy
Oil filer is new. I replace them about every 500 miles. They don't look chewed up or anything. As far as enemies..I might have a few. I have been reving the bike up with open header. Neighbors might be trying to shut me up.
13 Sep 2006 14:28 #76499 by Jeff.Saunders
Replied by Jeff.Saunders on topic What the heck is this on my oil pump?
Could it be the remains of a paper towel or a shop towel? It does look fiberous.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
13 Sep 2006 15:17 #76520 by fixer5000
Replied by fixer5000 on topic What the heck is this on my oil pump?
whatever the heck it is its nasty looking damn!!!
1978 kz650b pretty much stock
massachusetts
