Where does this o ring go?
- tullymars
08 Sep 2006 05:34 #75237
by tullymars
Where does this o ring go? was created by tullymars
- wiredgeorge
08 Sep 2006 05:37 #75239
by wiredgeorge
Replied by wiredgeorge on topic Where does this o ring go?
Dunno what it is called but it sure looks like the oring that is sandwiched between the cases that sits atop the oil pump journal.
- tullymars
08 Sep 2006 05:38 #75241
by tullymars
Replied by tullymars on topic Where does this o ring go?
Maybe this will be more help
secure.mycart.net/catalogs/catalog.asp?p...26584&showprevnext=1
- tullymars
08 Sep 2006 05:40 #75242
by tullymars
wiredgeorge wrote:
I agree,I just dont recall this o ring in the tranny,its been more than ten years since Ive had a kz apart so I dont recall everythingDunno what it is called but it sure looks like the oring that is sandwiched between the cases that sits atop the oil pump journal.
- Sandy
- Fly High,Tony
- Thank you received: 13
08 Sep 2006 07:48 #75262
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Where does this o ring go?
Did You have Your oil pump off?
1977 KZ1000 A-1
- wiredgeorge
08 Sep 2006 07:58 #75263
by wiredgeorge
You have to remove the oil pump to split the cases. The oring sits atop the lower case as the lower case will be pointing upwards when you split the cases, generally. It wouldn't much matter if the pump was in place or not. I think there is another oring associated with the pump directly where it fits to the cases but can't recall for sure.
- vegasjetskier
08 Sep 2006 12:43 #75313
by vegasjetskier
Replied by vegasjetskier on topic Where does this o ring go?
Which model bike do you have?
- vegasjetskier
09 Sep 2006 17:27 #75534
by vegasjetskier
I checked the manual and the only two places I see an O-ring like this are between the two case halves and where the oil pump bolts on, like WiredGeorge said. That's for a KZ1000.
